02-22-2014 07:17 PM - edited 03-16-2019 09:51 PM
I hope this post finds itself in the correct place.
I have a Cisco 1760 Router with CME 4.1 running on it. We have had some changes and I would like to completely wipe the configuration on it. I would like to keep the actual firmware ios operating system on it but would like to get ride of any configuration changes made in the CLI. Is there a way to do this?
Thanks!
Solved! Go to Solution.
02-23-2014 07:50 AM
No, theres no way to reset CME or CUCM to a blank config, CME you would need to do the no version of all the commands you dont need/want
02-23-2014 07:50 AM
02-23-2014 08:28 AM
Erase running-config.
Rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
02-23-2014 08:39 AM
Can you find the below configuation?
Please rate all useful information
02-24-2014 02:23 PM
Thanks for your help. Since I don't want to erase the entire configuration, I guess I will just have to go back very carefully and make the changes manually since I can't wipe the config and start from a blank configuration. I appreciate your help.
