Community Member
Cisco CME 4.1 Factory Reset
I hope this post finds itself in the correct place.
I have a Cisco 1760 Router with CME 4.1 running on it.  We have had some changes and I would like to completely wipe the configuration on it.  I would like to keep the actual firmware ios operating system on it but would like to get ride of any configuration changes made in the CLI.  Is there a way to do this?
Thanks!
1 ACCEPTED SOLUTION
Re: Cisco CME 4.1 Factory Reset
No, theres no way to reset CME or CUCM to a blank config, CME you would need to do the no version of all the commands you dont need/want
java
if this helps, please rate
www.cisco.com/go/pdi
java
Re:Cisco CME 4.1 Factory Reset
Erase running-config.
Rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
Community Member
Thanks for your help.  Since I don't want to erase the entire configuration, I guess I will just have to go back very carefully and make the changes manually since I can't wipe the config and start from a blank configuration.  I appreciate your help.
263
