Cisco CME 4.1
I have a gentleman who came to me for some help and i didn't want to steer him in the wrong direction on how to fix his issue.
He is telling me that he was able to get CME installed but the translation rules aren't working. If you read below this is exactly
what he wrote me back.
"CME is installed but i can't get the translation dialing rules or whatever set properly"
Thanks in advance and have a great afternoon
1 ACCEPTED SOLUTION
Re: Cisco CME 4.1
Without a proper explanation, config, examples, etc no one really can tell you what's wrong or what to do.
I'd recommend you to review this links:
Voice Translation Rules
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Number Translation using Voice Translation  Profiles
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: Cisco CME 4.1
java
java
Re: Cisco CME 4.1
I will write him back and see if he can give me more info on the situation
219
