Cisco CME and Calls through SIP provider
Hello, friends.
There are Cisco (C2801-ADVENTERPRISEK9_IVS-M), Version 15.1 (4) M7.
Telephones connected to SCCP, registered SIP from the provider.
When I try to call to test number 4444 through sip in debug I see:
*Feb 10 01:51:25.317: //53363/2739DFE79696/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP XXXXXXXXXXX:5060;branch=z9hG4bK100D02077;rport=5060
From: "TEST" <sip:61@sip.zadarma.com>;tag=131CC60C-1D40
To: <sip:4444@sip.zadarma.com>;tag=b638310eda6e4a73cf10b7fe3c94c572.bef7
Call-ID: 27F407C2-910B11E3-969BFFC5-883A8A0E@92.63.108.115
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.zadarma.com", nonce="Uvf1OFL39Awnou/oMiaFQrf9jyybhFmf", qop="auth"
Server: kamailio (4.0.3 (x86_64/linux))
Content-Length: 0
*Feb 10 01:51:25.325: //53363/2739DFE79696/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4444@sip.zadarma.com:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXX:5060;branch=z9hG4bK100D02077
Date: Sun, 09 Feb 2014 21:51:25 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
Cisco при этом зарегана у провайдера SIP
DC#show sip-ua register status
Line peer expires(sec) registered P-Associ-URI
Configuration:
voice service voip
ip address trusted list
  ipv4 178.16.26.122 255.255.255.255
  ipv4 144.76.42.108 255.255.255.255
  ipv4 176.9.145.115 255.255.255.255
  ipv4 5.9.108.25 255.255.255.255
  ipv4 78.46.95.118 255.255.255.255
  ipv4 89.249.23.194 255.255.255.255
  ipv4 178.16.26.124 255.255.255.255
  ipv4 176.9.85.133 255.255.255.255
  ipv4 46.4.53.86 255.255.255.255
  ipv4 5.9.84.165 255.255.255.255
  ipv4 78.16.26.122 255.255.255.255
  ipv4 77.235.62.222 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice register global
max-dn 10
max-pool 10
voice register dn  1
number 150
voice register dn  2
number 151
voice translation-rule 9
rule 1 /^95/ //
voice translation-rule 1020
rule 1 /^.$/ /40232/
voice translation-profile outgoing
translate calling 1020
translate called 9
mgcp fax t38 ecm
mgcp profile default
dial-peer voice 2 voip
translation-profile outgoing outgoing
destination-pattern 95....
session protocol sipv2
session target sip-server
voice-class codec 1
no voice-class sip outbound-proxy
voice-class sip bind control source-interface FastEthernet0/0
voice-class sip bind media source-interface FastEthernet0/0
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 40232 password 7 XXXXXXXXXX realm sip.zadarma.com
authentication username 40232 password 7 XXXXXXXXXXXX realm sip.zadarma.com
registrar dns:sip.zadarma.com:5060 expires 3600
sip-server dns:sip.zadarma.com:5060
connection-reuse
host-registrar
150                              40001      12           no
40232                            -1         550          yes
SIP provider says cisco trying to call with the internal call number, and it is necessary in order that have an SIP provider:
Wrong Remote-Party-ID: "Vankuver" <sip:61@<my ip>>;party=calling;
Should be so sip:40232@<my ip>
Please help me!
2 ACCEPTED SOLUTIONS
You are missing a parameter called  "modify"
request INVITE sip-header From modify "\"(.*)\" <>" "\"\" <40232>"
Hi.Under sip-uano remote
Hi.
Under sip-ua
no remote-party-id
Carlo
Please rate all helpful posts "The more you help the more you learn"
Can you please post "debug voice ccapi inout" for an outbound call with "debug voice translation".
You only have single dial-peer configured?
Manish
Hi Aleksandr.
You can modify your FROM value on your INVITE through a sip profile applyed to your outgoing dialpeer
eg
Voice class sip-profile 10
voice-class sip profile 10
Carlo
I confused something in quotes ... I can not give the proper command
i tried:
request INVITE sip-header From "\"(.*)\" <>" "\"\" <40232>"
and
% Invalid input detected at '^' marker.
Thank you!
It works!
But I do not hear a voice,silence.
Registering on the inside interface cisco via IPSEC VPN with split tunnel (some networks)
*Feb 10 17:12:17.394: //54273/CC3A49EB9B7E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x6A59E708
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 150
Called Number            : 4444
Source IP Address (Sig  ):
Destn SIP Req Addr:Port  : 178.16.26.122:5060
Destn SIP Resp Addr:Port : 178.16.26.122:5060
Destination Name         : sip.zadarma.com
*Feb 10 17:12:17.394: //54273/CC3A49EB9B7E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media):
Source IP Port    (Media): 16632
Destn  IP Address (Media): 178.16.26.124
Destn  IP Port    (Media): 15826
Orig Destn IP Address:Port (Media): [ - ]:0
*Feb 10 17:12:17.554: //54272/CC3A49EB9B7E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x6A5B4EE8
Called Number            : 954444
Source IP Address (Sig  ): 92.63.108.115
Destn SIP Req Addr:Port  : :42294
Destn SIP Resp Addr:Port : <real ip of my lan from i connect to cisco vpn>:42294
Destination Name : <192.168.11.14 - ip in vpn tunnel>
Are you behind nat?
Please post the output of a debug ccsip message during a call setup.
Carlo
Yes, I behind nat.
*Feb 10 18:11:53.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:954444@192.168.1.1 SIP/2.0
Via: SIP/2.0/TCP 192.168.11.14:42294;branch=z9hG4bK-d8754z-e645887cf7416a27-1---d8754z-;rport
Max-Forwards: 70
Contact: <150>
To: "954444"<954444>
Call-ID: ZjUzNjkwMWMyZDAyYmY1OWU2NjgzYzQwZjYyZWM5ZGU.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Type: application/sdp
User-Agent: X-Lite release 1104o stamp 56125
Content-Length: 314
v=0
o=- 2 2 IN IP4 192.168.11.14
s=CounterPath X-Lite 3.0
c=IN IP4 192.168.11.14
t=0 0
m=audio 5724 RTP/AVP 107 0 8 101
a=alt:1 2 : gNONJ/Dj BaLJhmb/ 10.200.16.55 5724
a=alt:2 1 : DQ3e8qud c1qVrWui 192.168.11.14 5724
a=fmtp:101 0-15
a=rtpmap:107 BV32/16000
a=rtpmap:101 telephone-event/8000
a=sendrecv
*Feb 10 18:11:53.477: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4444@sip.zadarma.com:5060 SIP/2.0
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK1038E7FF
To: <>4444@sip.zadarma.com>
Date: Mon, 10 Feb 2014 14:11:53 GMT
Call-ID: 2051121A-919411E3-9C13FFC5-883A8A0E@92.63.108.115
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0541864002-2442400227-2618163141-2285537806
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392041513
Contact: <150>outside ip cisco cme:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 8076 2450 IN IP4 92.63.108.115
s=SIP Call
c=IN IP4 92.63.108.115
t=0 0
m=audio 18534 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
*Feb 10 18:11:53.481: //54340/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Feb 10 18:11:53.625: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP outside ip cisco cme:5060;branch=z9hG4bK1038E7FF;rport=5060
To: <>4444@sip.zadarma.com>;tag=9fedfddccf3bcc4a1975d2cdb2a664b8.7066
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.zadarma.com", nonce="Uvja/1L42dNbKQpCc2GzgagslkjyE1Pn", qop="auth"
Content-Length: 0
*Feb 10 18:11:53.633: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDPoutside ip cisco cme:5060;branch=z9hG4bK1038E7FF
From: "150" <>150@sip.zadarma.com>;tag=169E6BC4-1E16
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Feb 10 18:11:53.637: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDPoutside ip cisco cme:5060;branch=z9hG4bK1038F25FC
Min-SE:  1800
CSeq: 102 INVITE
Contact: <150>:5060>
Expires: 180
Proxy-Authorization: Digest username="40232",realm="sip.zadarma.com",uri="sip:4444@sip.zadarma.com:5060",response="df38cd7f4af8e4a808fbbfdf5a7dd6a1",nonce="Uvja/1L42dNbKQpCc2GzgagslkjyE1Pn",cnonce="E701683F",qop=auth,algorithm=md5,nc=00000001
Max-Forwards: 69
Content-Length: 262
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
*Feb 10 18:11:53.981: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 trying -- your call is important to us
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK1038F25FC;rport=5060
CSeq: 102 INVITE
Content-Length: 0
*Feb 10 18:11:54.385: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 92.63.X:5060;rport=5060;branch=z9hG4bK1038F25FC
Record-Route: <178.16.26.122>
To: <>4444@sip.zadarma.com>;tag=as7e8de8e5
CSeq: 102 INVITE
Server: Zadarma Voip
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Contact: <4444>
Content-Length: 281
v=0
o=root 1942395501 1942395501 IN IP4 178.16.26.124
s=Asterisk PBX
c=IN IP4 178.16.26.124
t=0 0
m=audio 12164 RTP/AVP 8 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
*Feb 10 18:11:54.409: //54341/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4444@178.16.26.124:5060 SIP/2.0
Via: SIP/2.0/UDP 92.63.xxxx.xxxx:5060;branch=z9hG4bK10390E63
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
*Feb 10 18:11:54.429: //54340/204C30429C0D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "954444"<954444>;tag=169E6F78-88E
CSeq: 1 INVITE
Contact: <4444>:5060;transport=tcp>
Supported: replaces
Supported: timer
Content-Length: 193
v=0
o=CiscoSystemsSIP-GW-UserAgent 149 3396 IN IP4 92.63.108.115
s=SIP Call
t=0 0
m=audio 17190 RTP/AVP 8
a=ptime:20
*Feb 10 18:11:54.653: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4444@92.63.108.115:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 91.231.141.230:42294;branch=z9hG4bK-d8754z-95374017c126c928-1---d8754z-;rport
Max-Forwards: 70
Contact: <150>
CSeq: 1 ACK
Content-Length: 0
Hi.
Can you please share a show voip rtp connections during an active call.
If you can, please attach also yuor running config
Carlo
DC#show voip rtp connections
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP     LocalIP                                RemoteIP
1     54611      54610      16604    19546                            178.16.26.124
Found 1 active RTP connections
I try to send config via email.
Hi Aleksandr.
From the above command, the second rtp stream from VG to IP phone doesn't appear.
That's could be the root issue.
Please share your entire vg configuration.
Carlo
Hello!
I sent you a letter with the configuration cisco yesterday by mail. Did not receive?
Hi Aleksandr.
Yes sorry, I checked my inbox just now.
Watching your config, I see different possible issues.
Which subnet is assigned to ip phones?
You have a route map rerouting traffic for subnet 192.168.1.0/24 to a different gateway.
Try also to add
voice service voip
media flow-around
Please let me know
Carlo
Thank you for your reply!
Phones are in defferent subnes 192.168.0.0/24, 2.0/24, 4.0/24 connect via vpn and gre tunnel.
No problems with calls from them. Problems,when I connect throuth vpn to VG and register the softphone on 192.168.1.1(inside ip VG). My VPN lan 192.168.11.0/24.
I added
media flow-around
1     55283      55280      17782    16230    outside-ip-cisco                          176.9.145.115
VIP Super Bronze
From what I can see here, the Ip Phones are been told by your CCME gateway to send their RTP stream to the public ip of the gateway (92.63.108.115)..The question is can they reach this IP? Looking at the Request URI, the INVITE from the X-lite was sent to the private IP of CCME (192.168.1.1) That suggests to me that those phones may not be ale to reach that public IP.
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Aleksandr,
We recieve a  "SIP/2.0 407 Proxy Authentication Required", you need to check with your Service Provider:
Received:
CSeq: 101 INVITE
Content-Length: 0
Kindly rate this post accordingly.
Kevin
Hi.
Please add what follows and send a debug ccsip
voice service voip
sip
bind all source f0/1
Carlo
Hello,friends!All worked, but
Hello,friends!
All worked, but again recently had a problem with outgoing calls with the same provider.
My config:
sip-ua
 credentials username 141756 password 7 pass realm sip.zadarma.com
 authentication username 141756 password 7 pass
 registrar 1 dns:sip.zadarma.com expires 3600
 connection-reuse
 host-registrar
 destination-pattern 9...........
 voice-class codec 1
 voice-class sip profiles 20
 dtmf-relay rtp-nte sip-notify
 no vad
voice class sip-profiles 20
 request INVITE sip-header From modify "\"(.*)\" <sip:(.*)@(.*)>" "\"\" <sip:141756@92.63.108.115>"
 rule 1 /^9/ //
voice translation-rule 1030
 rule 1 /^.*/ /141756/
 translate calling 1030
 translate called 9
debug ccsip message
Jun  4 23:08:51.247: //17386/1C4006E18C9A/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:79118268147@sip.zadarma.com:5060 SIP/2.0
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK4A51D1A
Remote-Party-ID: "Vankuver" <sip:141756@92.63.108.115>;party=calling;screen=no;privacy=off
From: "" <sip:141756@92.63.108.115>;tag=30056CAC-7EF
To: <sip:79118268147@sip.zadarma.com>
Date: Wed, 04 Jun 2014 18:08:51 GMT
Call-ID: 1DDB67F5-EB4A11E3-8C9FA529-5E0D91DD@92.63.108.115
Min-SE:  1800
Cisco-Guid: 0473958113-3947500003-2358945065-1577947613
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1401905331
Contact: <sip:141756@92.63.108.115:5060>
Call-Info: <sip:92.63.108.115:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Content-Length: 309
v=0
o=CiscoSystemsSIP-GW-UserAgent 4250 6098 IN IP4 92.63.108.115
s=SIP Call
t=0 0
m=audio 17138 RTP/AVP 0 18 8 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Jun  4 23:08:51.307: //17386/1C4006E18C9A/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK4A51D1A;rport=5060
To: <sip:79118268147@sip.zadarma.com>;tag=b638310eda6e4a73cf10b7fe3c94c572.53f6
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.zadarma.com", nonce="U49vk1OPbmeoTsQ5WUcB2MQbTNbuaDse", qop="auth"
Server: kamailio (4.1.2 (x86_64/linux))
Content-Length: 0
Jun  4 23:08:51.315: //17386/1C4006E18C9A/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:79118268147@sip.zadarma.com:5060 SIP/2.0
From: "Vankuver" <sip:141756@92.63.108.115>;tag=30056CAC-7EF
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK4A61F2E
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="141756",realm="sip.zadarma.com",uri="sip:79118268147@sip.zadarma.com:5060",response="2e910417008d2e2006242c70f531f177",nonce="U49vk1OPbmeoTsQ5WUcB2MQbTNbuaDse",cnonce="B1B29B16",qop=auth,algorithm=md5,nc=00000001
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Jun  4 23:08:51.819: //17386/1C4006E18C9A/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="141756",realm="sip.zadarma.com",uri="sip:79118268147@sip.zadarma.com:5060",response="2u e910417008d2e2006242c70f531f177",nonce="U49vk1OPbmeoTsQ5WUcB2MQbTNbuaDse",cnonce="B1B29B16",qop=auth,algorithm=md5,nc=00000001
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Jun  4 23:08:52.819: //17386/1C4006E18C9A/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 04 Jun 2014 18:08:52 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1401905332
Expires: 180
Proxy-Authorization: Digest username="141756",realm="sip.zadarma.com",uri="sip:79118268147@sip.zadarma.com:5060",response="2all
All possible debugging has been turned off
DC#e910417008d2e2006242c70f531f177",nonce="U49vk1OPbmeoTsQ5WUcB2MQbTNbuaDse",cnonce="B1B29B16",qop=auth,algorithm=md5,nc=00000001
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
My router reseive one message from SIP-provider:
Received:
CSeq: 101 INVITE
Content-Length: 0
IN debug ccsip errors I see:
SIP/Error/sipSPI_ipip_set_history_info_header: ccb->src_addr_str is NULL
Please,help me!!!
Hi Aleksandr.On your dialpeer
Hi Aleksandr.
On your dialpeer 2 remove voice class codec and force codec to g711ulaw.
Please try it and let me know.
Carlo
no effect:Sent:INVITE sip
no effect:
Sent:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK2417FB
From: "" <sip:141756@92.63.108.115>;tag=3035EC-1A5D
Date: Wed, 04 Jun 2014 20:44:50 GMT
Call-ID: E8B58412-EB5F11E3-8018FAC8-2C2E981E@92.63.108.115
Min-SE:  1800
Cisco-Guid: 3877290282-3948876259-2148793032-0741251102
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1401914691
Expires: 180
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 1053 2671 IN IP4 92.63.108.115
s=SIP Call
t=0 0
m=audio 19012 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Jun  5 01:44:51.067: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK2417FB;rport=5060
To: <sip:79118268147@sip.zadarma.com>;tag=b638310eda6e4a73cf10b7fe3c94c572.ea16
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.zadarma.com", nonce="U4+Bw1OPgJcXokYeoDfJkKMwzKC2C3v3", qop="auth"
Content-Length: 0
Jun  5 01:44:51.075: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Sent:
From: "Vankuver" <sip:141756@92.63.108.115>;tag=3035EC-1A5D
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun  5 01:44:51.079: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK251416
Date: Wed, 04 Jun 2014 20:44:51 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="141756",realm="sip.zadarma.com",uri="sip:79118268147@sip.zadarma.com:5060",response="ceb43d310176422368146b753373de99",nonce="U4+Bw1OPgJcXokYeoDfJkKMwzKC2C3v3",cnonce="805CE107",qop=auth,algorithm=md5,nc=00000001
Content-Length: 273
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Jun  5 01:44:51.579: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 273
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Jun  5 01:44:52.579: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 04 Jun 2014 20:44:52 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1401914692
Expires: 180
Content-Length: 273
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Jun  5 01:44:54.583: //31/E71AC12A8013/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 04 Jun 2014 20:44:54 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1401914694
Expires: 180
Content-Length: 273
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
 no vad
dial-peer voice 3 voip
 translation-profile incoming incoming
 incoming called-number 141756
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
voice class codec 1
Hi.
Under sip-ua
no remote-party-id
Carlo
Hi.On dialpeer 2 you removed
Hi.
On dialpeer 2 you removed voice-class codec as asked but you didn't add "codec g711ulaw" as I asked you.
Please modify the config with codec and previous suggestion and let me know.
Carlo
After adding no remote-party
After adding no remote-party-id all works.
My config:
sip-ua
 credentials username 141756 password 7 <pass> realm sip.zadarma.com
 authentication username 141756 password 7 <pass>
 no remote-party-id
 connection-reuse
 host-registrar
 preference 1
 destination-pattern 98..........
 voice-class codec 1
 no vad
Thank you!!!
984
