Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco CME: calls through SIP-provider again
Hello,friends!
I have already published a discussion here https://supportforums.cisco.com/discussion/12089656/cisco-cme-and-calls-through-sip-provider and you helped me, everything works well for Russian numbers.
When I tried to add the configuration for calls to Belarus, again, there was a problem. I do not understand why, although the configuration ideintichnaya.
My config:
voice service voip
 ip address trusted list
  ipv4 178.16.26.122 255.255.255.255
  ipv4 144.76.42.108 255.255.255.255
  ipv4 176.9.145.115 255.255.255.255
  ipv4 5.9.108.25 255.255.255.255
  ipv4 78.46.95.118 255.255.255.255
  ipv4 89.249.23.194 255.255.255.255
  ipv4 178.16.26.124 255.255.255.255
  ipv4 176.9.85.133 255.255.255.255
  ipv4 46.4.53.86 255.255.255.255
  ipv4 5.9.84.165 255.255.255.255
  ipv4 78.16.26.122 255.255.255.255
  ipv4 77.235.62.222 255.255.255.255
  ipv4 81.88.86.11 255.255.255.255
  ipv4 192.168.1.50 255.255.255.255
  ipv4 217.150.198.44 255.255.255.255
  ipv4 178.63.96.3 255.255.255.255
  ipv4 178.63.96.28 255.255.255.255
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 sip
  registrar server
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
voice class sip-profiles 20
 request INVITE sip-header From modify "\"(.*)\" <sip:(.*)@(.*)>" "\"\" <sip:141756@92.63.108.115>"
voice translation-rule 9
 rule 1 /^98/ /7/
voice translation-rule 10
 rule 1 /^9/ //
voice translation-rule 1020
 rule 1 /^.*$/ /141756/
voice translation-rule 1030
 rule 1 /^.*/ /141756/
voice translation-rule 1040
 rule 1 /^.*$/ /21/
voice translation-profile incoming
 translate called 1040
voice translation-profile outgoing
 translate calling 1030
 translate called 9
voice translation-profile outgoing-mezhdunarod
 translate called 10
voice-card 0
dial-peer voice 2 voip
 description TO-RUSSIA
 translation-profile outgoing outgoing
 preference 1
 destination-pattern 98..........
 session protocol sipv2
 session target sip-server
 voice-class codec 1
 no voice-class sip outbound-proxy
 voice-class sip profiles 20
 voice-class sip bind control source-interface FastEthernet0/0
 voice-class sip bind media source-interface FastEthernet0/0
 dtmf-relay rtp-nte sip-notify
 no vad
dial-peer voice 3 voip
 translation-profile incoming incoming
 incoming called-number 141756
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 4 voip
 description To-Belarus
 translation-profile outgoing outgoing-mezhdunarod
 destination-pattern 9375.........
 voice-class codec 1
 no vad
sip-ua
 credentials username 141756 password 7<pass> realm sip.zadarma.com
 authentication username 141756 password 7 <pass>
 no remote-party-id
 registrar 1 dns:sip.zadarma.com expires 3600
 sip-server dns:sip.zadarma.com
 connection-reuse
 host-registrar
DEBUG ccsip message:
Jun 17 14:23:09.033: //14293/D2C3B137AE52/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:375298911396@sip.zadarma.com:5060 SIP/2.0
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK36571F65
From: "" <sip:141756@92.63.108.115>;tag=40FCB218-23D7
To: <sip:375298911396@sip.zadarma.com>
Date: Tue, 17 Jun 2014 09:23:09 GMT
Call-ID: D48B9FA6-F53711E3-AE57FAC8-2C2E981E@92.63.108.115
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3536040247-4114026979-2924673736-0741251102
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1402996989
Contact: <sip:141756@92.63.108.115:5060>
Call-Info: <sip:92.63.108.115:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 309
v=0
o=CiscoSystemsSIP-GW-UserAgent 6656 8059 IN IP4 92.63.108.115
s=SIP Call
c=IN IP4 92.63.108.115
t=0 0
m=audio 18252 RTP/AVP 0 18 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Jun 17 14:23:09.089: //14293/D2C3B137AE52/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK36571F65;rport=5060
To: <sip:375298911396@sip.zadarma.com>;tag=b638310eda6e4a73cf10b7fe3c94c572.6d40
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.zadarma.com", nonce="U6AYAFOgFtT86kmu2Fr5tYxLYGEexIl1", qop="auth"
Server: kamailio (4.1.2 (x86_64/linux))
Content-Length: 0
Jun 17 14:23:09.169: //14293/D2C3B137AE52/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:375298911396@sip.zadarma.com:5060 SIP/2.0
From: "Vankuver" <sip:141756@92.63.108.115>;tag=40FCB218-23D7
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 92.63.108.115:5060;branch=z9hG4bK365820F2
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="141756",realm="sip.zadarma.com",uri="sip:375298911396@sip.zadarma.com:5060",response="9534322838cbf2e265b2004bc0aa240e",nonce="U6AYAFOgFtT86kmu2Fr5tYxLYGEexIl1",cnonce="FFF9A231",qop=auth,algorithm=md5,nc=00000001
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Jun 17 14:23:09.637: //14293/D2C3B137AE52/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Jun 17 14:23:10.621: //14293/D2C3B137AE52/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 17 Jun 2014 09:23:10 GMT
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1402996990
Expires: 180
All possible debugging has been turned off
DC#231",qop=auth,algorithm=md5,nc=00000001
Content-Length: 309
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
Debug voice ccapi inout:
 Destination Pattern=9375........., Called Number=375298911396, Digit Strip=FALSE
Jun 17 15:22:13.073: //14425/13366763AF35/CCAPI/ccCallSetupRequest:
   Calling Number=141756(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=375298911396(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Vankuver
   Account Number=, Final Destination Flag=FALSE,
   Guid=13366763-F540-11E3-AF35-FAC82C2E981E, Outgoing Dial-peer=4
Jun 17 15:22:13.073: //14425/13366763AF35/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=141756
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=375298911396
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 17 15:22:13.073: //14425/13366763AF35/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6968AA04, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=141756,(Calling Name=Vankuver)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=375298911396(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=4, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 17 15:22:13.073: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 17 15:22:13.073: :cc_get_feature_vsa malloc success
Jun 17 15:22:13.077:  cc_get_feature_vsa count is 2
Jun 17 15:22:13.077: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 17 15:22:13.077: :FEATURE_VSA attributes are: feature_name:0,feature_time:1819298856,feature_id:3371
Jun 17 15:22:13.077: //14427/13366763AF35/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jun 17 15:22:13.077: //14427/13366763AF35/CCAPI/ccCallSetContext:
   Context=0x6C726BF4
Jun 17 15:22:13.077: //14425/13366763AF35/CCAPI/ccSaveDialpeerTag:
Jun 17 15:22:13.085: //14427/13366763AF35/CCAPI/cc_api_call_proceeding:
Please help me... I don't know what to do!
could you please attach the
could you please attach the complete debug output with calling/called number details?
//Suresh Please rate all the useful posts.
Hello!Thank you for your
Hello!
Thank you for your reply.
Debug voice  ccapi inout in attach.
I'm calling from the number 84 on the German number(for test) 49374574447200 trough 9.
You need to contact service
You need to contact service provider for this , after authentication challenge your sip provider is not sending any response.
Contact them and ask whether they had received INVITE with proxy authentication details or not.
136
