Cisco CME config with Skype Connect error
DOUGLAS DRURY
I've configured my CME with a sip connection from Skype but i can't seem to figure out why i can't make outgoing or incomming calles.  Would sombody be able to tell me where i have gone wrong please.
in advance.  Usernames and passwords in the config have been changed.
Internal calls work
no ip domain lookup
ip domain name TEK-SERV.local
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  no update-callerid
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice translation-rule 1111
rule 15 /^...$/ /88051000228349/
voice translation-rule 2222
rule 2 /^80/ //
rule 3 /^80/ /0044/
voice translation-profile skype
translate calling 1111
translate called 2222
voice-card 0
no dspfarm
username phoneeng privilege 15 secret 5 $1$vWm6$7HiP3sqDZ7a5D94tmw9xd.
archive
log config
  hidekeys
no ip ftp passive
dial-peer voice 101 voip
description skype outgoing
translation-profile outgoing skype
destination-pattern 8.T
voice-class sip profiles 1000
session protocol sipv2
session target dns:sip.skype.com
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 88051000228349 password 0 password realm sip.skype.com
authentication username 88051000228349 password 0 password
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
connection-reuse
  host-registrar
g729-annexb override
telephony-service
no auto-reg-ephone
load 7914 S00104000100
load 7902 CP7902060000SCCP050124A.sbin
load 7905 CP7905060000SCCP050124A.sbin
load 7906 SCCP11.8-3-3S.loads
load 7911 SCCP11.8-3-3S.loads
load 7912 CP7912060000SCCP050124A.sbin
load 7920 cmterm_7920.4.0-02-00.bin
load 7960-7940 P00307020200
max-ephones 42
max-dn 42
ip source-address 192.168.16.1 port 2000
system message TEK SERV
url messages http://192.168.16.1:80/messages
cnf-file location flash:
date-format dd-mm-yy
voicemail 3099
max-conferences 8 gain -6
hunt-group logout HLog
moh flash:/music-on-hold.au
web admin system name ADMIN secret 5 $1$vo27$4gASd5vT0G4S68DVHmzBE1
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 901771622598 name Test
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys hold  Join Newcall Resume Select
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback
softkeys alerting  Acct Callback Endcall
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
ephone-dn  1  dual-line
number 3001
pickup-group 3097
label 3001
description IS
name I S
ephone-dn  2  dual-line
number 3002
pickup-group 3097
label DDI-3002
name Jon Dow
ephone-dn  3  dual-line
number 3003
pickup-group 3097
label 3003
description Douglas Drury
name Douglas Drury
ephone-dn  4  dual-line
number 3004
pickup-group 3097
ephone  1
mac-address 0012.0101.0C75
username "IS"
type 7940
button  1:1
ephone  2
mac-address 001E.ECE9.E966
username "jdow"
type CIPC
button  1:2
ephone  3
mac-address 0012.00EC.B345
username "ddrury" password 3003
fastdial 1 3099 name c
type 7940
button  1:3
pin 3003
ephone-hunt 1 sequential
pilot 3098
list 3001, 3002, 3003, 3004
no-reg pilot
description Service Desk
line con 0
logging synchronous
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
end
TEK-SERV-CME#
23 Replies 23
Hi Douglas.
Can you please attach the output of a debug ccsip messages during an outgoing and incoming call?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
I tried to run the dbug ccsip messages command but when i made an outgoing and incoming call nothing appeared on the command prompt.  I did run some other debug ccsip commands and did get some outputs but only from outgoing calls, incoming didn't do anything.  I can see from my Skype Connect dashboard that by cme has successfully connected.
Dbug ccsip error
*Jan 19 12:16:00.719: //34/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
*Jan 19 12:16:00.727: //35/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
*Jan 19 12:16:00.735: //36/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
*Jan 19 12:16:00.743: //37/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
Debug ccsip info
*Jan 19 12:17:52.291: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x47E2218C) with key=[37] to table
*Jan 19 12:17:52.291: //43/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
*Jan 19 12:17:52.291: //43/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 43, peer_callID = 42
*Jan 19 12:17:52.291: //43/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
*Jan 19 12:17:52.291: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : sip.skype.com target_port : 5060
*Jan 19 12:17:52.295: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIUaddccCallIdToTable: Adding
TEK-SERV-CME# call id 2B to table
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Jan 19 12:17:52.295: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetCallConfig: voice class SIP Profiles tag is set : 1000
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIGetCallConfig: Not using Voice Class Codec
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sip_gw_pre_setup_add_sdp_container: DNS/ENUM resolution required; Deferred Creating SDP
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
*Jan 19 12:17:52.295: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddPrivacyandIdentityInfo: ccb->local_host_name,ccb->src_addr_str is NULL
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/act_idle_continue_call_setup:
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x47E2218C key=8D937E87-803A11E3-8029A333-29708665@192.168.15.1
*Jan 19 12:17:52.295: //43/86A66BB48024/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 8D937E87-803A11E3-8029A333-29708665@192.168.15.1
*Jan 19 12:17:52.299: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: TYPE SRV query for _sip._udp.sip.skype.com and type:1
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name 1.sip.skype.com
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 0 Weight 0 Port 5060
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name 2.sip.skype.com
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 1 Weight 0 Port 5060
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Selected Server is 1.sip.skype.com
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: IP Address of 1.sip.skype.com is:
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: 63.209.144.201
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 43
*Jan 19 12:17:52.359: //43/86A66BB48024/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Jan 19 12:17:52.359: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Jan 19 12:17:52.363: //43/86A66BB48024/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Jan 19 12:17:52.363: //43/86A66BB48024/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
*Jan 19 12:17:52.363: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Jan 19 12:17:52.363: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar host retrieved
*Jan 19 12:17:52.363: //43/86A66BB48024/SIP/Info/sipSPISendInvite: Associated container=0x4874F6A4 to Invite
*Jan 19 12:17:52.363: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_change_sdp_line: SDP header is removed : c=IN IP4 192.168.15.1
*Jan 19 12:17:52.363: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_update_content_length: Content length header before modification : Content-Length: 247
*Jan 19 12:17:52.367: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_update_content_length: Content length header after modification : Content-Length: 224
*Jan 19 12:17:52.367: //43/86A66BB48024/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Jan 19 12:17:52.367: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Jan 19 12:17:52.531: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 63.209.144.201:5060
*Jan 19 12:17:52.531: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Jan 19 12:17:52.531: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Jan 19 12:17:52.535: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 63.209.144.201:5060
*Jan 19 12:17:52.535: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Jan 19 12:17:52.535: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Jan 19 12:17:52.535: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Jan 19 12:17:52.539: //43/86A66BB48024/SIP/Info/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 404
*Jan 19 12:17:52.539: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[43], src[4]
*Jan 19 12:17:52.539: //43/86A66BB48024/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(1) for outgoing call
*Jan 19 12:17:52.539: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Jan 19 12:17:52.539: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Jan 19 12:17:52.539: //43/86A66BB48024/SIP/Info/ccsip_call_statistics: Requesting stats for callid=43
*Jan 19 12:17:52.539: //43/86A66BB48024/SIP/Info/ccsip_call_statistics: Stats request failed for callid=43, dstCallID=-1, rc=-7
*Jan 19 12:17:52.539: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
*Jan 19 12:17:52.539: //43/86A66BB48024/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:104746 ConnTime 0
*Jan 19 12:17:52.543: //43/86A66BB48024/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 2B
Hi Douglas,
you call has been disconnected with cause code 1 indicating unallocated/unassigned called number.
'404 Not Found' indicates there is no route to reach the destination. you may need to check the translation rule also.
According to the RFC
21.4.5. 404 Not Found
   The server has definitive information that the user does not exist at
   the domain specified in the Request-URI.  This status is also
   returned if the domain in the Request-URI does not match any of the
   domains handled by the recipient of the request.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Hi Douglas.
You don't see anything probably because you are not yet registered.
Please post the output of a show sip-ua register status
Carlo
Hi Carlo,
Sorry for the delay in getting back to you.  Below is the output from the sh sip-ua register status command
TEK-SERV-CME#sh sip-ua register status
Line          peer           expires(sec)  registered
3001          20001            51            no
3002          20002            42            no
3003          20003            51            no
3004          20004            51            no
880510002283  -1               51            no
990510002283  -1               222           yes
TEK-SERV-CME#
Doug
DOUGLAS DRURY
Anyboddy able to help?
Hi Douglas
From your config it seems that you are registring number 88051000228349 while form the output of show sip-ua register status the number 990510002283 is registerd.
Also from your confing, I cannot see any incoming dialpeer.
Please activate a debug ccsip messages and a debug voip dialpeer inout and post the result.
Carlo
Hi Carlo,
I've enabled the debug ccsip messages and a debug voip dialpeer inout and also sh sip-ua register status.
3001          20001            38            no
3002          20002            38            no
3003          20003            38            no
3004          20004            38            no
990510002283  -1               199           yes
TEK-SERV-CME#
*Jan 26 15:48:55.530: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3001, Called Number=, Voice-Interface=0x47F2A2B8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
*Jan 26 15:48:56.050: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8
   Result=Partial Matches(1) after DP_MATCH_DEST
*Jan 26 15:48:56.050: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
*Jan 26 15:48:56.150: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=80, Peer Info Type=DIALPEER_INF
TEK-SERV-CME#O_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=80
*Jan 26 15:48:56.150: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.250: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=801, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=801
*Jan 26 15:48:56.250: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.350: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8017, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8017
*Jan 26 15:48:56.350: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.450: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=80177, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=80177
*Jan 26 15:48:56.450: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.550: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=801771, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=801771
*Jan 26 15:48:56.550: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.650: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8017716, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8017716
*Jan 26 15:48:56.650: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.750: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=80177162, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=80177162
*Jan 26 15:48:56.750: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.850: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=801771622, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=801771622
*Jan 26 15:48:56.850: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:56.950: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8017716225, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8017716225
*Jan 26 15:48:56.950: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:57.050: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=80177162259, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=80177162259
*Jan 26 15:48:57.050: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
*Jan 26 15:48:57.150: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=801771622598, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=801771622598
*Jan 26 15:48:57.150: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
TEK-SERV-CME#
TEK-SERV-CME#
*Jan 26 15:49:07.150: //-1/3258081D80B5/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=801771622598T, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=801771622598T
   Result=Success(0) after DP_MATCH_DEST
*Jan 26 15:49:07.150: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=101
   Result=SUCCESS(0)
TEK-SERV-CME#   List of Matched Outgoing Dial-peer(s):
*Jan 26 15:49:07.154: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=801771622598, Called Number=801771622598, Peer Info Type=DIALPEER_INFO_SPEECH
*Jan 26 15:49:07.154: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jan 26 15:49:07.154: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=801771622598, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
   Result=SUCCESS(0)
*Jan 26 15:49:07.158: //-1/3258081D80B5/DPM/dpMatchPeersCore:
*Jan 26 15:49:07.158: //-1/3258081D80B5/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jan 26 15:49:07.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1771622598@sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK24F4A1
To: <>1771622598@sip.skype.com>
Date: Sun, 26 Jan 2014 15:49:07 GMT
Call-ID: 3946F001-85D811E3-80BA8A8C-20FD358A@192.168.15.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 844630045-2245530083-2159381132-553465226
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1390751347
Contact: <3001>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 224
v=0
o=CiscoSystemsSIP-GW-UserAgent 1250 6992 IN IP4 192.168.15.1
s=SIP Call
t=0 0
m=audio 19192 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Jan 26 15:49:07.450: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <>1771622598@sip.skype.com:5060;maddr=63.209.144.201;transport=udp>
Content-Length: 0
*Jan 26 15:49:07.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: <>1771622598@sip.skype.com>;tag=ca90d13f-13c4-52e52905-5f93cf67-5178fb15
CSeq: 101 INVITE
Content-Length: 0
*Jan 26 15:49:07.462: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1771622598@sip.skype.com:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
TEK-SERV-CME#
TEK-SERV-CME#
Hi Douglas.
Under sip-ua configuration section, try to add what follows:
calling-info sip-to-pstn number set 990510002283
After that, attach again a debug ccsip messages during an outgoing call.
Carlo
Hi Carlo,
Thanks for your reply.  See the below outout during an outgoing call.
TEK-SERV-CME(config-sip-ua)#calling-info sip-to-pstn number set 990510002283
TEK-SERV-CME#debug ccsip messages
SIP Call messages tracing is enabled
TEK-SERV-CME#
*Jan 26 20:14:37.445: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=3003, Called Number=, Voice-Interface=0x4888BB84,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20003
*Jan 26 20:14:37.969: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:37.969: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.065: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=80, Peer Info Type=DIALPEER_INFO_SPEECH
*Jan 26 20:14:38.065: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.165: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.169: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.269: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.269: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.365: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.369: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.465: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.469: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.469: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.569: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.569: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.669: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.669: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.765: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.769: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.865: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.869: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:38.969: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:38.969: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:39.065: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:39.065: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
*Jan 26 20:14:49.065: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:49.065: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jan 26 20:14:49.069: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jan 26 20:14:49.069: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jan 26 20:14:49.069: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
*Jan 26 20:14:49.073: //-1/5077CF4A81C3/DPM/dpMatchPeersCore:
*Jan 26 20:14:49.073: //-1/5077CF4A81C3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jan 26 20:14:49.141: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK3FEDB9
From: "Douglas Drury" <>3003@sip.skype.com>;tag=20AA140-1338
Date: Sun, 26 Jan 2014 20:14:49 GMT
Call-ID: 57661B07-85FD11E3-81C88A8C-20FD358A@192.168.15.1
Min-SE:  1800
Cisco-Guid: 1350029130-2247954915-2177075852-553465226
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1390767289
Contact: <3003>
Expires: 180
Content-Length: 224
v=0
o=CiscoSystemsSIP-GW-UserAgent 2197 9313 IN IP4 192.168.15.1
s=SIP Call
t=0 0
m=audio 17200 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*Jan 26 20:14:49.309: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Jan 26 20:14:49.313: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>1771622598@sip.skype.com>;tag=ca90d13f-13c4-52e5674b-60870b9e-58d26086
CSeq: 101 INVITE
Content-Length: 0
*Jan 26 20:14:49.321: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Jan 26 20:14:53.593: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK3FF323
From: <>99051000228349@sip.skype.com>;tag=20AB2A4-1CF
To: <>99051000228349@sip.skype.com>
Date: Sun, 26 Jan 2014 20:14:53 GMT
Call-ID: 83237ABC-85D411E3-80798A8C-20FD358A
Max-Forwards: 70
Timestamp: 1390767293
CSeq: 81 REGISTER
Contact: <99051000228349>
Expires:  3600
Content-Length: 0
*Jan 26 20:14:53.749: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>99051000228349@sip.skype.com>;tag=c990d13f-68db6745-0-d01b920a-0
CSeq: 81 REGISTER
Contact: <99051000228349>;expires=300
Expires: 300
Content-Length: 0
*Jan 26 20:15:10.193: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK400C01
To: <>3001@sip.skype.com>
Date: Sun, 26 Jan 2014 20:15:10 GMT
Call-ID: A8280998-85AD11E3-80038A8C-20FD358A
Max-Forwards: 70
Timestamp: 1390767310
CSeq: 192 REGISTER
Contact: <3001>
Expires:  3600
Content-Length: 0
*Jan 26 20:15:10.201: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK401E81
To: <>3002@sip.skype.com>
Call-ID: A82C4F48-85AD11E3-80048A8C-20FD358A
Max-Forwards: 70
CSeq: 192 REGISTER
Contact: <3002>
Expires:  3600
Content-Length: 0
*Jan 26 20:15:10.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK4021C35
To: <>3003@sip.skype.com>
Call-ID: A8313121-85AD11E3-80058A8C-20FD358A
Max-Forwards: 70
CSeq: 192 REGISTER
Contact: <3003>
Expires:  3600
Content-Length: 0
*Jan 26 20:15:10.221: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bK403DC1
To: <>3004@sip.skype.com>
Call-ID: A85053E0-85AD11E3-80068A8C-20FD358A
Max-Forwards: 70
CSeq: 192 REGISTER
Contact: <3004>
Expires:  3600
Content-Length: 0
*Jan 26 20:15:10.349: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
To: <>3001@sip.skype.com>;tag=c990d13f-69d8c0e9-0-d01bd2e2-0
CSeq: 192 REGISTER
Contact: <3001>
Expires: 3600
Content-Length: 0
*Jan 26 20:15:10.357: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>3002@sip.skype.com>;tag=c990d13f-69d8dec4-0-d01bd2e9-0
CSeq: 192 REGISTER
Contact: <3002>
Expires: 3600
Content-Length: 0
*Jan 26 20:15:10.365: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>3003@sip.skype.com>;tag=c990d13f-69d8fbf4-0-d01bd2f1-0
CSeq: 192 REGISTER
Contact: <3003>
Expires: 3600
Content-Length: 0
*Jan 26 20:15:10.377: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>3004@sip.skype.com>;tag=c990d13f-69d92b8e-0-d01bd2fd-0
CSeq: 192 REGISTER
Contact: <3004>
Expires: 3600
Content-Length: 0
TEK-SERV-CME#
Hi Douglas.
Please remove voice-class sip profile from your dialpeer 101 and try again with calling-info configured under sip-ua as previously suggested.
Please attach again debug info after this change.
Carlo
HI Carlo,
I did what you suggested.
TEK-SERV-CME#
TEK-SERV-CME#
TEK-SERV-CME#
*Jan 27 20:02:43.483: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Jan 27 20:02:44.003: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.007: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.103: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.103: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.203: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.203: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.303: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.303: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.403: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.403: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.503: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.503: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.603: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.603: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.703: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.703: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.803: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.803: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:44.903: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:44.903: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:45.003: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:45.003: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:45.103: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:45.103: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
*Jan 27 20:02:55.103: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:55.103: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jan 27 20:02:55.107: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jan 27 20:02:55.107: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Jan 27 20:02:55.107: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
*Jan 27 20:02:55.111: //-1/D15302638619/DPM/dpMatchPeersCore:
*Jan 27 20:02:55.111: //-1/D15302638619/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Jan 27 20:02:55.179: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:801771622598@sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.15.1:5060;branch=z9hG4bKD02D19
From: "Douglas Drury" <>3003@sip.skype.com>;tag=726185C-1E98
To: <>801771622598@sip.skype.com>
Date: Mon, 27 Jan 2014 20:02:55 GMT
Call-ID: D841E9AE-86C411E3-861E8A8C-20FD358A@192.168.15.1
Min-SE:  1800
Cisco-Guid: 3511878243-2260996579-2249820812-553465226
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1390852975
Contact: <3003>
Expires: 180
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 8242 2820 IN IP4 192.168.15.1
s=SIP Call
t=0 0
m=audio 18920 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*Jan 27 20:02:55.347: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <>801771622598@sip.skype.com:5060;maddr=63.209.144.201;transport=udp>
Content-Length: 0
*Jan 27 20:02:55.351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>801771622598@sip.skype.com>;tag=ca90d13f-13c4-52e6b603-65a26999-6aed16dd
CSeq: 101 INVITE
Content-Length: 0
*Jan 27 20:02:55.359: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:801771622598@sip.skype.com:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Hi Douglas
Please attach you actual config after my suggestions.
Which IOS version are you running?
Carlo
Thanks for the quick reply Carlos.
TEK-SERV-CME#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 22:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
TEK-SERV-CME uptime is 40 minutes
System returned to ROM by reload at 20:07:40 UTC Mon Jan 27 2014
System image file is "flash:c2800nm-spservicesk9-mz.124-20.T.bin"
2 FastEthernet interfaces
1 ATM interface
1 terminal line
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
TEK-SERV-CME#sh run
Building configuration...
Current configuration : 8049 bytes
version 12.4
hostname TEK-SERV-CME
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$y.zY$GKXukChzuToVc6iM5hklf/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.16.1 192.168.16.9
ip dhcp excluded-address 192.168.16.21 192.168.16.254
ip dhcp excluded-address 192.168.15.1 192.168.15.9
ip dhcp excluded-address 192.168.15.21 192.168.15.254
ip dhcp pool ccp-pool1
   network 192.168.15.0 255.255.255.0
   domain-name TEk-SERV
   dns-server 192.168.15.1
   default-router 192.168.15.1
   option 150 ip 192.168.15.1
   lease 0 0 30
ip domain name sip.skype.com
ip name-server 8.8.8.8
voice service voip
sip
  no update-callerid
rule 15 /^...$/ /99051000228349/
rule 1 /^800/ //
rule 2 /^80/ //
rule 3 /^80/ /0044/
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-2390328788
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2390328788
revocation-check none
rsakeypair TP-self-signed-2390328788
crypto pki certificate chain TP-self-signed-2390328788
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333930 33323837 3838301E 170D3134 30313237 32303130
  31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33393033
  32383738 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CAAF 0A72C584 2D2D955A C92C88D4 A34EAD56 F29BC64B 10C0365B 912BFB0F
  3DD0E99A 6D9A8456 23AAD153 D5222101 A4AA8218 74F37ECA 2421674B 238F25D6
  AF3921C8 42B39613 ECC4E076 9FB2C908 4F483067 B354A58C B988A2EA 2518D87A
  AC045F94 D2CE284F 6FB8A71F 7DB2AB37 E30AEBA6 7A179D34 B75454D5 CEFEAEF2
  F89D0203 010001A3 7A307830 0F060355 1D130101 FF040530 030101FF 30250603
  551D1104 1E301C82 1A54454B 2D534552 562D434D 452E7369 702E736B 7970652E
  636F6D30 1F060355 1D230418 30168014 189BEE29 ED03961B EF943011 FE3AC57D
  FB9850FC 301D0603 551D0E04 16041418 9BEE29ED 03961BEF 943011FE 3AC57DFB
  9850FC30 0D06092A 864886F7 0D010104 05000381 81007FB1 8903C28F 985A44C9
  10966C29 E245515D AF4404FC EB83EA4D 2AAE356F 00BC1222 1AD4E2A2 90488F0F
  13F58E25 F1E843DC 471420F7 12537776 75EC27C4 A131B69A 6EF0ABA8 61B1FCBC
  DF5EAC56 CA68A47A 85B4CB10 2488B350 17D97884 6314B55D 2BF0374B 725151D1
  CD0EB9B3 EAB0562F 30BF932F C608DF24 0EFDD662 005E
        quit
archive
log config
  hidekeys
no ip ftp passive
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.15.1 255.255.255.0
duplex auto
speed auto
interface Service-Engine0/0
ip address 192.168.11.252 255.255.255.0
service-module ip address 192.168.11.251 255.255.255.0
service-module ip default-gateway 192.168.11.252
interface FastEthernet0/1
description CME_MANEGMENT_INT
ip address 192.168.10.253 255.255.255.0
duplex auto
speed auto
interface ATM0/3/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.15.254
ip http server
ip http authentication local
ip http secure-server
tftp-server flash:CP7902060000SCCP050124A.sbin alias CP7902060000SCCP050124A.sbin
tftp-server flash:CP7905060000SCCP050124A.sbin alias CP7905060000SCCP050124A.sbin
tftp-server flash:CP7905060000SCCP050124A.zup alias CP7905060000SCCP050124A.zup
tftp-server flash:SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
tftp-server flash:CP7912060000SCCP050124A.sbin alias CP7912060000SCCP050124A.sbin
tftp-server flash:S00104000100.sbn alias S00104000100.sbn
tftp-server flash:cmterm_7920.4.0-02-00.bin alias cmterm_7920.4.0-02-00.bin
tftp-server flash:P00307020200.loads alias P00307020200.loads
tftp-server flash:P00307020200.bin alias P00307020200.bin
tftp-server flash:P00307020200.sb2 alias P00307020200.sb2
tftp-server flash:P00307020200.sbn alias P00307020200.sbn
control-plane
dial-peer cor custom
name test
dial-peer cor list out
member test
description Skype Outgoing
translation-profile outgoing Skype
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 99051000228349 password 7 073E366954223D063404590B5C233D realm sip.skype.com
authentication username 99051000228349 password 7 1426052E162F0E28073E61327A1A11
no remote-party-id
retry invite 2
retry register 10
timers connect 100
connection-reuse
  host-registrar
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 42
voicemail 3099
dn-webedit
time-webedit
ephone-template  1
number 3001
pickup-group 3097
label 3001
description IS
name I S
number 3002
pickup-group 3097
label DDI-3002
name Jon Dow
number 3003
pickup-group 3097
label 3003
name Douglas Drury
number 3004
pickup-group 3097
ephone  1
username "IS"
type 7940
button  1:1
ephone  2
username "jdow"
type CIPC
button  1:2
ephone  3
type 7940
button  1:3
pin 3003
pilot 3098
no-reg pilot
line con 0
logging synchronous
line aux 0
line 194
no exec
transport input all
line vty 0 4
login local
