Cisco CME FXO Issue.
Hello. I am using a Cisco 1760 with a FXO VIC Card. The config for the Dial-Plan/FXO is below.
The issue I am having is how to get CME to ignore incomming calls. With this config, outbound works great.
When a call comes in, CME picks it up, gives a dial tone, and stops the analouge phones from riging.
Any ideas to what I should change in the config?
Thanks!
voice translation-rule 100
voice-port 2/0
voice-port 2/1
dial-peer voice 1 pots
description INCOMING MATCHING
call-block translation-profile incoming BlockCalls
preference 1
destination-pattern 9[6]..........
incoming called-number .
port 2/0
forward-digits 11
prefix 9,
dial-peer voice 9 pots
description OUTGOING LEVEL 9 CALLS
destination-pattern 9T
port 2/0
telephony-service
load 7910 P00405000700
load 7960-7940 P00308000400
load 7920 cmterm_7920.4.0-03-02.bin
load 7941 SCCP41.8-2-2SR1S
load 7961 SCCP41.8-2-2SR1S
Green
Re: Cisco CME FXO Issue.
against voice port 2/0 use plar to an extension you would like to answer the call on.
voice-port 2/0
connection plar 500
This will ring incoming calls on extn 500
Alex
Regards, Alex. Please rate useful posts.
What I am hoping to do is have the older analouge phone system and the cisco system using the same PTNS phone line/number. Outboud calling works great, I do not want the cisco system to do anything with incoming callings, I only want the older analouge system to be able to answer them.
Thanks.
I'm assumming that you analogue system is connected to port 2/1.
What you can do is to configure COR "Class of Restriction" which will allow you to permitt/deny traffict to only match the dial-peers that you give access to.
Here is an example config:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Hope this is what you are looking for.
- Luis A.
The setup is as below
Service Provider Line---Splitter----Cisco FXO Card & Base of Analogue System
Cisco FXO is in a Voice Router that handels a dozen phones
Analogue system is a business phone system with answering machine and a few wireless handsets.
Thanks.
Ok. Do you have an FXS port also in the CME? If you do, I will use that instead to connect your Analogue System and virtually route inbound using COR or connection PLAR, since trying to control an split signal will be complicated.
Otherwise the CME will most likely answer sooner than the answering machine and not know what to do.
-Luis A.
I do not have a FXS port. So, I should get a FXO card, and use that?
Will I be able to make it possible for the users of the analouge system to dial like normal without any prefixs or delays?
Yes. Basically you CME will be acting as the PSTN for you Analogue system, that way you can tell CME to route all inbound traffic to the FXS port.
-Luis A.
Okay.
Also, will Caller ID Information pass through?
Here is the list of FXO cards that support caller ID:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
-Luis A.
When ordering a FXS card, is the a model needed to pass the caller ID info from the FXO to the system on the FXS?
There is a set of requirements that need to be meet.
Here are some examples:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_voice_configuration_library_glossary/vclclid.html#wp1077886
- Luis A.
1395
