cisco CME fxo port outgoing and incoming call busy
Good Day,I have Head office Router,where I connect cisco CME with 4 IP Phones,all ip phones can talk to each other as well before It was support outgoing and incoming pstn call through 4 fxo port.
right now I am not able to make a call outside as well i can't receive a call,it is giving the busy tone when ever you are making a call outside.
I have the following configuration,please anybody can help me.
Building configuration...
Current configuration : 4370 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname CME-HQ
boot-start-marker
boot-end-marker
enable secret 5 $1$96Am$W2cevvuvT7CxcU64YWPgL.
no aaa new-model
clock timezone GMT3 3 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.1.1.250 10.1.1.254
ip dhcp excluded-address 10.10.1.250 10.10.1.254
ip dhcp excluded-address 10.1.1.1 10.1.1.30
ip dhcp excluded-address 10.10.1.1 10.10.1.30
ip dhcp pool Voice
network 10.10.1.0 255.255.255.0
option 150 ip 10.10.1.252
default-router 10.10.1.252
ip dhcp pool DATA
network 10.1.1.0 255.255.255.0
option 150 ip 10.1.1.252
default-router 10.1.1.252
voice-card 0
voice translation-rule 1
rule 1 /^063391996/ /6/
voice translation-rule 2
rule 1 /^6/ /063391996/
voice-card 0
voice translation-profile pstn-in
translate called 1
voice translation-profile pstn-out
translate calling 2
license udi pid CISCO2921/K9 sn FCZ1539201L
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 password 7 00071A150754525F56
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.252 255.255.255.0
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 10.10.1.252 255.255.255.0
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.497
encapsulation dot1Q 497
ip address 172.16.245.110 255.255.255.252
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1/0
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface Vlan1
no ip address
router bgp 65272
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.0
network 10.10.1.0 mask 255.255.255.0
neighbor 172.16.245.109 remote-as 65000
neighbor 172.16.245.109 ebgp-multihop 2
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source static 10.1.1.3 84.235.84.5
ip route 0.0.0.0 0.0.0.0 84.235.84.6
control-plane
voice-port 0/0/0
translation-profile incoming pstn-in
translation-profile outgoing pstn-out
signal groundStart
connection plar opx 6003
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
dial-peer voice 1 pots
destination-pattern 9T
no digit-strip
port 0/0/0
dial-peer voice 2 pots
destination-pattern ^0.........
no digit-strip
port 0/0/0
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 70
max-dn 120
ip source-address 10.1.1.252 port 2000
system message Serbal Trading Co Ltd
time-zone 31
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1  dual-line
number 6001
ephone-dn  2  dual-line
number 6002
ephone-dn  3  dual-line
number 6003
ephone-dn  4
number 6004
name Naseer Khan
ephone  1
mac-address 0008.308B.8DF7
button  1:1
ephone  2
mac-address 24B6.57B1.F240
button  1:2
ephone  3
mac-address 24B6.57B1.F340
button  1:3
ephone  4
mac-address D0C2.82D0.EFBB
button  1:4
line con 0
password 7 01100F1758045F5678
logging synchronous
login
line aux 0
password 7 121A0C041104555D73
login
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
password 7 05080F1C2243175040
logging synchronous
login
transport input all
scheduler allocate 20000 1000
end
CME-HQ-#
CME-HQ-#
CME-HQ-#
Can you directly connect Analog Phone and try making inbound/Outbound call if you are getting line busy This might be the problem from PSTN.
Thanks for your reply,I   already tried through POTS directly it is working fine,when connect through FXO not working.
Before It was worked fine almost one month.
Remove the following from voice-port 0/0/0 and make a test call
Yes I removed and tried still same problem.
Can you run Debug dial peer command
Add the following commands under Voice Port 0/0/0 and make a test call
compand-type a-law
timeouts interdigit 4
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
Your Dial-peer configuration shows "no digit-strip " command which means that  you are send 9 along with rest of the dialing number
debug voip ccapi inout
debug vpm signal
debug voip vtsp all
show voice port summary
make a out-bound call. let me know the results.
Kevin Monteiro
Hi everybody
It is working now,without doing any modifications,What I done is just shutdown the CME,remanove the fx0 interface from one socket and put it into another socket,It was before on voice-port 0/0/0 after changing that it becames 0/1/0.
Thanks for all your efforts to support.
Best Regards
Shanawaz
Hi Meer,
thanx for your post it is very helpful. the same issue was here as well but i am still not able to dial an international calls it is fine with national calls can any one help in this regard.
CME_Router#
translate called 1
translate calling 2
oice-port 1/1/0
signal groundStart
connection plar opx 5555
caller-id enable
no digit-strip
port 1/1/0
no digit-strip
port 1/1/0
thanks
7357
