Cisco CME: Reserve an outgoing FXO port for a group of internal extension?
Hi Experts,
I just came across a situation where a client required that a particular PSTN line (that is connecting to FXO 0 on a CME, for example) is reserved for outgoing calls for a small group of internal extensions (let's say it's 8010 to 8019). I did some research but could not find anything relevant.
Could anyone please help me by showing me whether it's possible to do with a Cisco CME? If so, what is the feature called?
Thank you very much in advanced for your time and for sharing your wisdom.
Nhan.
1 ACCEPTED SOLUTION
You'll need cor list like this
dial-peer cor custom
name pt-internal
name pr-external
dial-peer cor list css-internal
member pt-internal
dial-peer cor list css-external
member pt-external
dial-peer voice 9 pots
destination-pattern 9[2-9]......
corlist out css-external
ephone-dn 1
number 8010
corlist incoming css-internal
ephone-dn 2
number 8019
dont forget to rate post
name pt-internal
name pr-external
member pt-internal
member pt-external
ephone-dn 1
number 8010
ephone-dn 2
number 8019
Re: Cisco CME: Reserve an outgoing FXO port for a group of inter
Here, this is a little easier to understand. I have it setup so that extension 2001 will always use FXO port 2/1 for outgoing calls and extension 2002 will always use FXO port 2/0 for outgoing calls.
name port100
name port200
dial-peer cor list use100
member port100
dial-peer cor list use200
member port200
dial-peer voice 100 pots
corlist outgoing use100
description 10 Digit Dialing
destination-pattern 9[2-9]..[2-9]......
port 2/1
forward-digits 10
dial-peer voice 101 pots
description Long Distance Dialing
destination-pattern 91..........
port 2/1
forward-digits 11
dial-peer voice 201 pots
corlist outgoing use200
port 2/0
forward-digits 10
dial-peer voice 202 pots
port 2/0
forward-digits 11
dial-peer voice 10 voip
corlist incoming use100
answer-address 2001
dial-peer voice 20 voip
corlist incoming use200
answer-address 2002
ephone-dn 1
number 2001
pickup-group 5000
name PHONE-3
call-forward busy 3000
call-forward noan 3000 timeout 20
ephone-dn 2
number 2002
pickup-group 5000
name PHONE-4
Thank you very much for your time, ttemirgaliyev and nanosynth, both of you have helped me meet the customer's requirements and discover another usage of COR list.
641
