Cisco CME SIP Authentication
ericw
I'm testing out a SIP trunk on my Cisco CME, but can't get it  to authenticate correctly to the ITSP.  A packet capture shows that the  CME is trying to authenticate using <extension#>@1.2.3.4 but the  ITSP requires <areacode+phonenumber>@1.2
.3.4.  Is there any way to force CME to do this?
Here is my config with the test SIP trunk in place.
GMIT-VOICEROUTER01#sh config
Using 8775 out of 245752 bytes
! Last configuration change at 13:10:05 boston Sat Nov 30 2013 by cisco
! NVRAM config last updated at 13:10:06 boston Sat Nov 30 2013 by cisco
version 12.4
service password-encryption
hostname GMIT-VOICEROUTER01
boot-start-marker
boot system flash c2800nm-adventerprisek9_ivs_li-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone boston -4
clock summer-time boston recurring
dot11 syslog
no ip source-route
ip cef
ip dhcp pool Voice
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
   dns-server 8.8.8.8 8.8.4.4
   option 150 ip 172.16.2.1
ip domain name domain
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
voice-card 0
username xxxxx privilege 15 password 7 xxxxxxxxxxx
archive
log config
  hidekeys
interface Loopback0
description MANAGEMENT
ip address 172.16.254.4 255.255.255.255
interface FastEthernet0/0
ip address 66.55.220.166 255.255.255.252
ip nat outside
ip virtual-reassembly
shutdown
duplex full
speed 100
interface Service-Engine0/0
ip address 172.16.4.250 255.255.255.0
service-module ip address 172.16.4.251 255.255.255.0
service-module ip default-gateway 172.16.4.251
interface FastEthernet0/1
ip address x.x.x.x x.x.x.x
duplex full
speed 100
interface FastEthernet0/1.10
encapsulation dot1Q 10 native
ip address 192.168.5.2 255.255.255.0
ip nat inside
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.16.3.1 255.255.255.0 secondary
ip address 172.16.2.1 255.255.255.0
ip nat inside
router eigrp 100
redistribute static
passive-interface default
no passive-interface Service-Engine0/0
no passive-interface FastEthernet0/1
no passive-interface Loopback0
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.5.1
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:gui
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 101 permit ip 172.16.0.0 0.0.255.255 any
nls resp-timeout 1
cpd cr-id 1
snmp-server community xxxxx RO
tftp-server flash:OS79XX.TXT
tftp-server flash:P00307010200.bin
tftp-server flash:P00307010200.loads
tftp-server flash:P00307010200.sb2
tftp-server flash:P00307010200.sbn
tftp-server flash:TERM41.DEFAULT.loads
tftp-server flash:Jar41.2-9-1-45.sbn
tftp-server flash:cnu41.2-7-5-50.sbn
tftp-server flash:CVM41.2-0-1-45.sbn
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
ring number 2
connection plar opx 7001
description Connected to 20x-xxx-xxxx
caller-id enable type 1
voice-port 0/1/1
ring number 2
connection plar opx 7002
shutdown
dial-peer voice 3 voip
description *** Voicemail Extension 7000 - Do not delete! ***
destination-pattern 7000
session protocol sipv2
session target ipv4:172.16.4.251
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
description *** 10 Digit Calls On Voice Port 0/1/0 ***
destination-pattern [2-9]..[2-9]......
port 0/1/0
dial-peer voice 2 pots
description *** 11 Digit Calls On Voice Port 0/1/1 ***
destination-pattern 1[2-9]..[2-9]......
port 0/1/0
dial-peer voice 4 pots
description *** 7 Digit Calls On Voice Port 0/1/0 ***
destination-pattern [2-9]......
port 0/1/0
dial-peer voice 2000 voip
destination-pattern 200.
codec g711ulaw
dial-peer voice 10 voip
description Incoming Call from SIP Trunk
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
description to Cell
destination-pattern 20xxx7[1-9]
voice-class codec 1
session transport udp
dtmf-relay rtp-nte
no vad
sip-ua
credentials username xxxxxxxxxx password 7 xxxxxxxx realm xxx.net
authentication username xxxxxxxxxx password 7 xxxxxxxx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server ipv4:172.16.4.251 expires 3600 port 5060 transport udp
registrar dns:sbc2.xxx.net expires 3600
sip-server dns:sbc2.xxx.net
gatekeeper
shutdown
telephony-service
max-ephones 42
max-dn 100
ip source-address 172.16.3.1 port 2000
auto assign 1 to 10
system message GMIT
url services http://phone-xml.berbee.com/menu.xml
load 7960-7940 P00307010200
voicemail 7000
mwi relay
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name xxxxx secret 5 $1$UfDD$ffCmnvpfJnT5NpJBgnDfk1
dn-webedit
transfer-system full-blind
transfer-pattern 1001
night-service weekday 17:00 07:30
night-service weekend 23:59 23:59
create cnf-files version-stamp 7960 Oct 13 2012 19:30:35
ephone-dn  1  dual-line
number 7010
description Eric
name Eric
call-forward busy 7000
call-forward noan 7000 timeout 10
mwi-type both
mwi sip
ephone-dn  2  dual-line
number 7011
description Jenn
name Jenn
mwi-type both
mwi sip
ephone-dn  3  dual-line
number 7012
description Charly
name Charly
mwi-type both
mwi sip
ephone-dn  4  dual-line
number 7013
description Tim
name Tim
mwi-type both
mwi sip
ephone-dn  5  dual-line
number 7014
description Michelle
name Michelle
mwi-type both
mwi sip
ephone-dn  6  dual-line
number 7015
description Jessica
name Jessica
mwi-type both
mwi sip
ephone-dn  7  dual-line
number 7016
description Jonathan
name Jonathan
mwi-type both
ephone-dn  8  dual-line
number 7017
description Tech Bench
mwi-type both
ephone-dn  9  dual-line
number 7018
description Server Room
mwi-type both
ephone-dn  10
ephone-dn  11
number 8000
mwi on
ephone-dn  12
number 8001
mwi off
ephone-dn  13  dual-line
number 7001
label xxx-xxxx
name xxx-xxxx
huntstop channel
ephone-dn  14  dual-line
number 7002
label xxx-xxxx
name xxx-xxxx
huntstop channel
ephone-dn  15
call-forward night-service 2000
night-service bell
ephone-dn  91
number xxxxxx5122 no-reg primary
label xxx-5122
description SIP Trunk 1
ephone  1
device-security-mode none
mac-address 0019.E778.4559
type 7960
button  1:1 2m2 3m3 4m4
button  5:13 6:14
ephone  2
mac-address 000E.D76D.F67C
type 7960
button  1:2 5:13 6:14
ephone  3
mac-address 000E.D72E.46E0
type 7960
button  1:3 5:13 6:14
ephone  4
mac-address 000E.D76E.0192
type 7960
button  1:4 5:13 6:14
ephone  5
mac-address 000E.8461.296E
type 7960
button  1:5 5:13 6:14
ephone  6
mac-address 000E.D76E.019F
type 7960
button  1:6 2:91 5:13 6:14
ephone  7
mac-address 000D.BD40.7F37
type 7960
button  1:7
ephone  8
mac-address 0013.C472.847D
type 7960
button  1:8
ephone  9
mac-address 0007.5012.1B41
type 7960
button  1:9
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 194
password 7 00071A150754
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password 7 1511021F0725
logging synchronous
login local
transport input telnet ssh
line vty 5 15
logging synchronous
login local
scheduler allocate 20000 1000
ntp update-calendar
ntp server tock.usno.navy.mil prefer
end
3 Accepted Solutions
William Bell
Eric,
You can address your requirement by using translation profiles. Let's assume you have 4-digit extensions and that you want to prefix NPANXX to the extension. For instance:
Extensions: 2XXX
NPANXX: 202555
We can address the need with the following:
voice translation-rule 10
rule 1 /^2...$/ /202555\0/
voice translation-profile cme-to-itsp
translate calling 10
dial-p v 100 voip
description Example Egress Dial Peer to ITSP
destination-patt
translation-profile out cme-to-itsp
HTH.
-Bill (http://ucguerrilla.com)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Sure. Using the same (or similar) example:
Extensions: 2XXX
Primary Phone: 2025552000
rule 1 /^2...$/ /2025552000/
dial-p v 100 voip
destination-patt
HTH.
-Bill (http://ucguerrila.com)
Hi Eric
Alternatively to what William Suggested (+5P) you can use sip-profile to modify the invite field.
Eg.
voice class sip-profiles 1
request INVITE sip-header From modify "<>" "" where XXXX = is areacode+primaryphone#
Apply this sip profile to your outgoing dialpeer and your requests to your TSP should be ok.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
William Bell
Eric,
Extensions: 2XXX
NPANXX: 202555
dial-p v 100 voip
destination-patt
HTH.
Thank you for your reply Bill!
My situation is a little different, in that I have a bunch of phones but my SIP trunk only has 4 channels, and I have no DID's.  All my calls must authenticate using the same @1.2.3.4.  Can this be accomplished?
Extensions: 2XXX
dial-p v 100 voip
destination-patt
HTH.
Hi Eric
Eg.
Carlo
