Community Member
Cisco configuration assistant with CME
Hi All,
does CCA support CME? i know it supports UC500, I am trying to connect to CME by CCA, it keeps asking username and password.
thanks
Alex
Hall of Fame Super Red
Re: Cisco configuration assistant with CME
Hi Alex,
CCA only supports Cisco Smart Business Communications System (SBCS) platforms which
does not include CME Check out Table 1 in the attached link;
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps7256/ps7287/product_data_sheet0900aecd80603104.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Cisco Configuration Professional for Cisco Access Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps9422/data_sheet_c78_462210.html
Rob, is correct about CCA.  I would add that there is another tool called CCP (Cisco Configuration Professional) which is a replacement for SDM
that supports CME configuration via GUI interface.
Brandon
-- please remember to rate and mark answered helpful posts --
1161
