03-30-2010 11:15 AM - edited 03-15-2019 10:02 PM
Using CCP 2.1 with CallManager Express 7.1, I go to Voice > Phone Firmware > Select the phone firmware version to upload (which is 7941-7961-sccp.8-4-2S.tar) to flash and get back "Error the syntax of the field macAddress is not proper"
Known bug?
This is a C3945 with CME 7.1
03-30-2010 12:55 PM
I see that you insist using GUIs and similar stuff, now if these don't work, what can you do about ?
Use CLI and enjoy solid results.
03-30-2010 06:53 PM
If you post your config, we can help that way. We cant help you with GUI interfaces....
Anthony
