03-19-2014 03:17 PM - edited 03-16-2019 10:11 PM
Hope someone can shed some light. I have a few Cisco CP-9971 phones that will not boot and stuck on blank screen and amber light on first left and right buttons. Trying to bring them back to life. I have tried factory reset but didn't work. Is there other way to get in or flash firmware at this condition? Or am I looking at hardware issue? I have accumulated about 15 of those little over a year from other offices. Warranty likely expired. Some were out of box failure and some lost power and never come back up.
CUCM: version 9.1.1
Phone SIP firmware: sip9971.9-3-2-10
Thank you in advance.
Best,
Wilbur
Solved! Go to Solution.
03-19-2014 08:44 PM
If you have tried connecting these phones to known working switchports and also the factory reset then most likely the phones need to be replaced.
Manish
03-19-2014 08:44 PM
Manish
04-14-2014 05:00 PM
Hi Mgogna,
Sorry for the late reply. I had to update my profile email address and took a while. Thank you for your input. Yes, to both. I guess I'm out of luck on this.
Thx again.
Best W.
