Cisco CP7821 Supported CME 8.6
Hi All,
I need to know if the new IP Phone 7821/41/61 can support CME 8.6 or I need to Upgrade to  the latest version of CME to support that phones.
If someone already did a deployment with a CP 7821 with CME 8.6 just let me know.
Regards.
  • IP Telephony
Phone compatibility is
Phone compatibility is here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks Jaime, unfortunately
Thanks Jaime, unfortunately the CP 7821 doesn't support CME 8.6.
We had to install CME 11
We had to install CME 11 experimental edition to support 7800 Series.. and seeing that is experimental, expect to see a few bugs.
Ben
You have to upgrade the CME
You have to upgrade the CME version to 10 and add the 78XX phones using fast track method
CME 10 Fast Track Configuration steps for 7821 SIP Phone
voice register pool-type  7821
no phoneload-support
no telnet-support
transport tcp
num-lines 4
reference-pooltype 6921
voice register pool  5
busy-trigger-per-button 1
id mac 6C41.6A36.9890
session-transport tcp
type 7821
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
no vad
433
