Cisco CTI Manager event log error
I've been getting this error for some time now on both of my Call Managers. I can't find any information about it via google or cisco.com. Does anyone know what causes this?
Event Type: Warning
Event Source: Cisco CTIManager
Event Category: None
Event ID: 2
Date: 11/16/2006
Time: 8:06:59 AM
User: N/A
Computer: CM-2CORP
Description:
Warning: kCtiMytcpErrSocketBroken - Socket connection broken.
App ID: Cisco CTIManager
Cluster ID: CM-1CORP-Cluster
Node ID: 10.1.2.12
Explanation: TCP connection is lost.
Recommended Action: Although connection to the application is lost, no action is required if lost connection was intentional..
Re: Cisco CTI Manager event log error
what version of callmanager.
Error Message
CCM_CTI-CTI-4-kCtiMytcpErrSocketBroken : Socket connection broken.
Explanation TCP connection is lost.
Recommended Action Although connection to the application is lost, no action is required if lost connection was intentional.
System Error Messages for Cisco Unified CallManager 5.0:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/prod_error_message09186a008063610b.html
Cisco Unified CallManager Error and System Messages:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_system_message_guides_list.html
4.1(3)
no services releases installed yet
Unfortunatley those documents lack any solutions for how to fix the CTI problem.
I have seen this before on a working CCM 3.3(4) sr2 system after it was working fine for awhile on 3-4 occassions now. We went to TAC on this error and issue in past because when it happened to us the IPCC Express call center stopped working. A reboot of Call Manager servers fixed the issue, but TAC couldn't find cause of issue and we took lots of traces during time of problem, and double checked all the configuration also.
Sorry couldn't be more helpful on this, as I would like to find the cause to this to. It has (knock on wood) been awhile since it happened last for me.
It doesn't appear to be causing any serious issues. I just don't like having the errors in my event logs.
272
