05-17-2012 05:18 AM - edited 03-16-2019 11:12 AM
I need to configure 2 CUBE in Active / Standby configuration. Must I buy 1 x FL-CUBEE-100-RED or 2 x FL-CUBEE-100-RED, one for each device?
05-17-2012 06:27 AM
No, you only need FL-CUBEE-100 for the primary CUBE and one FL-CUBEE-100-RED for the stanby CUBE. RED is only used for the redundant stanby CUBE.
HTH,
Chris
10-09-2013 10:16 AM
says
so only order what you need for the total number of sessions and the license will transfer upon failure.
05-17-2012 06:38 AM
According this question on link
4.4 Ordering an Active/Standby Redundant Pair
To order a redundant pair of Cisco Unified Border Element platforms to be deployed in an Active/Standby configuration, do the following:
Step 1. Select one of the following platform choices. Order two of these platforms, one for the Active, one for the Standby.
a. Select Cisco 2900, 3900, 3900E from Table 1, or
b. Select an ASR1001, ASR1002 or ASR1004 platform, or
c. Select a Cisco 2900, 3900, 3900E bundle from Table 8
Step 2. Select a software image or package:
a. If you are ordering Cisco 2900, 3900 or 3900E Series platforms, select one or more software packages from Table 5. The Unified Communications package is required; the Security package is optional.
b. If you are ordering Cisco ASR1000 Series platforms, select a software image from Table 1 that has the feature complement you require.
Step 3. Select a single Redundant-Platform license (to cover both the Active and Standby platforms) from Table 3.
Alex.
Please rate useful posts.
