Community Member
Cisco cuc "tell the last and first name " then press #
Dear All,
when we press the message button we are hearing the below message and why is that ?
we are using cuc 9 for voice mail and AA and even the AA is not working
please help
1 ACCEPTED SOLUTION
VIP Super Bronze
Either you have changed the Opening Greeting Call Handler such that it is moving you to a Directory Handler with ASR/Speech Connect enabled; or, you have changed the Direct Routing Rules to do the same thing.
Verify that the routing rules are correct, then go review your call handler.
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
Dear All,
"spell the last and first name " then press #
please help
VIP Super Bronze
Community Member
dear Jonathan,
you are correct, number days before I've created a direct routing rule and it was the reason that brought the issue. Now solved after deleting the Direct routing rule thanks a lot !.
best regards
kennedy
174
