Cisco CUCM 10.x integration with Panasonic TDA 600 using Cisco SPA8800
Hi everyone,
As my subject above,
I've plan to integrate Cisco CUCM v10.x with Panasonic TDA600 using Cisco SPA8800,
the idea is :
CUCM --sip trunk--> SPA8800 --analog trunk--> Panasonic TDA600
Panasonic TDA600 --analog trunk--> SPA8800 --sip trunk--> CUCM
PSTN connection will connected via Panasonic TDA600.
My questions :
1. Is it call from Cisco IP Phone that register to CUCM will be able to make a call to Panasonic Analog Phone that register to Panasonic TDA600 and vise versa?
2. Can I use RJ-21 50-pin connector on SPA8800 for Analog trunk to Panasonic TDA600? or I just can use RJ-11?
2. Any other solution to integrate CUCM 10.x with Panasonic TDA600 using analog trunk / E1 trunk / SIP trunk / H323 trunk?
Please Advise,
Ovindo
we usetda600  ---- E1 ----
we use
tda600  ---- E1 ---- 2911Cube --- sip trunk --- cucm
insted 2911 you can use 2801
Hi Tagir, What licenses that
Hi Tagir,
What licenses that you need on 2911 for that scenario?
Currently 2801 is EoS, can I just Use ISR 1900 series or ISR 800?
Ovindo
according to documentaion in
according to documentaion in your case spa8800 will work too
Hi Tagir,i'm trying to do the
Hi Tagir,
i'm trying to do the same integration, can you share the docs that you consult to integrate vía SIP Trunk the spa8800 with the CUCM¿?
Rgds
Vicente
298
