Community Member
Cisco CUCM 9.1.1.20000-5 Fresh Install On MCS7816I5-K9-CMD2 Problems
Supportforum,
I'm having issues with a fresh installation of CUCM version 9.1.1.20000-5 on a new MCS server MCS7816-I5-K9-CMD2.
Has anyone seen the error below before?
I'm also seeing the "Hardware Detection Error" as described in https://supportforums.cisco.com/message/3969182
Both the hardware and software are good according to the compatibility matrix.
I've successfully installed the software but I'm unable to login at the CLI command prompt.
Any ideas, suggestion would be appreciated.
Thanks in advance.
Ric
I would double check that you hardware meets the requirements.  Your server model might match but are you sure of the other components such as disk size and RAM have not been edited
Check link below against what you have
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)#Version_9.1.28x.29
Purple
Hi Ric,
What is the error message u get while u login into CLI mode?
I suggest opening u a TAC case with Cisco and share the resolution  since in earlier attached Post we did not get any resolution.
regds,
aman
Community Member
Hi Aman, Gregory,
No error message when logging into the CLI.  The Last login message flashes up very breifly on the screen and it just rolls back to request login details. If I use the wrong credentials it prompts me.
This is actually the second time I've seen this, the original server for this project was 7825-I5 and it brought up the same errors with 9.1(2). The hardware specifications meet the requirements from what I can see.
I'm going to open a TAC case and request an older version of software, say 9.1(0). I don't see anything on the matrix for 9.1(2) and this hardware.
I'll post anything useful here.
thanks,
Community Member
I'm having the same issue with the CLI.  Did you get this resolved?  If so what was the fix?
J
813
