11-13-2013 08:47 AM - edited 03-16-2019 08:23 PM
Hi Experts
I have integration between Cisco CUCM and Ericsson , on Ercisson i have RP which is 9*72**852#then number for outgoing call. I need to do RP on CUCM to route to this RP on Ercisoon as 9* so it will go to Ericsson and this will be to allow outgoing calls be recorde by billing syste of Ericsson, I need help to set up RP which will allow 9* , how can * be dialed as digit????.
Solved! Go to Solution.
11-13-2013 09:48 AM
* is a valid digit, so there is nothing that you need to do but enter it in the route pattern.
Chris
11-13-2013 09:48 AM
Chris
11-13-2013 10:12 AM
Hi MR/Chris
I am so pleased that you confirm and i am sure that i will get a correct answer from you. i will test and tell you feedback by tomorrow.
11-13-2013 10:15 AM
Sounds good, if it works for you please mark the question as answered.
Chris
11-13-2013 10:30 AM
Chris
I am sure this correct answer from now before my test.Thanks again.
