Community Member
Cisco CUCME and Asterisk(Elastix) Integration Question
Hello almighty community!!
I´ve have the following scenario: CUCME (192.168.1.251) ======== SIP TRUNK ========= ELASTIX  (192.168.1.3)
I found the following config which worked:
voice service voip
address-hiding
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
dial-peer voice 3000 voip
destination-pattern 3...
session protocol sipv2
session target ipv4:192.168.1.3
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 6000 voip
description **Llamadas entrantes Troncal SIP**
translation-profile incoming AsteriskTrunk
destination-pattern 6000
codec g711ulaw
sip-ua
keepalive target ipv4:192.168.1.3
credentials username 5000 password wxyz realm 192.168.1.3
authentication username 5000 password wxyz
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar ipv4:192.168.1.3 expires 3600
sip-server ipv4:192.168.1.3:5060
But the problem is that only CUCME is registering against Asterisk server, but not viceversa. The person whos managing the Asterisk server provide me this info
host=192.168.1.251
username=6000
secret=wxyz
Register String
6000:wxyz@192.168.1.251
, so i´m suppose to make something in CUCME to allow it to register, but as you may have notice by now, i´m not an expert, this is the first time i´m trying to acomplish this. How can i do this?. The result  by the moment is that an IP phone connected to Asterisk can call a Cisco IP phone but when i try to call back from the Cisco IP phone to the Asterisk phone, it doesn´t work. The Asterisk PBX sees that a call is coming but it doesn´t establish it. Also, de Caller-ID
that Asterisk sees is 5000. I need that CID to be calling party number. For this last thing i was thinking to do this:
voice translation-rule 1
  rule 1 /^3\(...\)/ /3\1/
voice translation-profile AsteriskCID
translate called 1
translation-profile outgoing AsteriskCID
But im not sure if that should work. Any help would be appreciated. Thanks
Community Member
Hello! everyone who could give any idea about this subject? Thanks in advance.
Community Member
Hello Andres..
Do you need to get the CME to become as a register server for the asterisk server?
With this config:
sip-ua
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
The CME will send sip registrations to 192.168.1.3
In order to convert the CME to a register server you need todo:
-ena
-config t
-voice service voip
-sip
-registrar server
With this the CME will accept SIP register messages coming in.
Hope it helps
Community Member
Hola Richard!
Actually, i want to test both scenarios. The first one worked for me but then i try it using ip addressess on the data VLAN and stop working. Your answer is helpfull because clarifies me some doudbts but, i´m supposed to register the asterisk box on CME being like a register server using authentication, because the asterisk box is also sending me some credentials (
6000:wxyz@192.168.1.251). How could i perform this?. Thanks again for your help, and if you could tell me about this last issue, it will be great.
AF.
2530
