Community Member
Cisco CUE upgrade from 3.0.4 to 7.0.1
Hi all:
I am having a problem upgrading the unity express module from 3.0.4 to 7.0.1
Originally I successfully upgraded from 2.1.2 to 3.0.4 by following the cisco documentation BY CLEAN INSTALL ,
however when I go from 3.0.4 to 7.0.1 as either CLEAN INSTALL or UPGRADE, I am getting the error message as below.
then I try to upgrade every step possible as going to from 3.0.4 to 3.1.1 or 3.2.1 and so on, every time I get the same error message
Can any one kindly help me please? I would really appreciate for your help.
I checked with Cisco matrix I am way above the minimum required condition for CUE to run such as ISO 12.4(22) / CME-7 / Cisco 2811
Current version
CUE# show software versions
Installed Packages:
Software Version: 3.0.4
- Installer 3.0.4.0
- Thirdparty 2.3.1.0
- Bootloader (Primary) 2.1.14
- Infrastructure 2.3.2.0
- Global 3.0.4.0
- GPL Infrastructure 2.2.1.0
- Voice Mail 2.3.1.0
- Bootloader (Secondary) 2.1.15.0
- Core 2.4.0.1
- Auto Attendant 3.0.0.12
Installed Plug-ins:
- CUE Voicemail Language Support 3.0.0.0
- CUE Voicemail US English 3.0.0.0
error message
from 3.0.4 to 7.0.1
CUE# $0.10.10.1/cue-vm-k9.nme.7.0.1.pkg username cisco password cisco
WARNING:: This command will install the necessary software to
WARNING:: complete a clean install. It is recommended that a backup be done
WARNING:: before installing software.
WARNING:: The system will briefly be brought to an offline state
WARNING:: This will terminate any active call and prevent new calls
WARNING:: from being processed.
Would you like to continue? [n] y
system/batch_mode: no such node/attribute
Downloading ftp cue-vm-k9.nme.7.0.1.pkg
Bytes downloaded : 182508
Validating package signature ... done
sh: line 1: boot_debug: command not found
Validating installed manifests ............complete.
Service Engine Bootloader can not be installed on this platform/chassis combination.
From 3.0.4 to 3.1.1
CUE# $.10.10.1/cue-vm-k9.nme.3.1.1.pkg username cisco password cisco
Downloading ftp cue-vm-k9.nme.3.1.1.pkg
Bytes downloaded : 178361
Hall of Fame Super Gold
Re: Cisco CUE upgrade from 3.0.4 to 7.0.1
Sometime clean or upgrade simply do not work.
You only choice is backup, install from bootloader, restore.
Hall of Fame Super Red
Hi Uthth,
Just to tag on to the good tips from my friend Paolo (+5 points bud!)
It looks to me like you may be using the wrong files. The clip that
you pasted shows .nme files. Perhaps you are actually using either
AIM-CUE or NM-CUE which use different Software as shown below;
Cisco Unity Express Version 3.1.1
Cisco Unity Express Release 3.1.1 Utilities
Cisco Unity Express Release 3.1.1 Sample Interactive Voice Response Scripts
Cisco Unity Express Release 3.1.1 Sample Auto-Attendant Scripts
Cisco Unity Express Release 3.1.1 NME Software and Language Files
Cisco Unity Express Release 3.1.1 License Files
Cisco Unity Express Release 3.1.1 AIM and NM Software and Language Files
http://www.cisco.com/cgi-bin/tablebuild.pl?topic=282773313
Hope this helps!
Rob
1305
