Community Member
Cisco CUPS 7.0.6 and SIP phone 8961
Is it possible for ip phone 8961 SIP to run with CUPs 7.0.6 and CUCM version 7.1.5?
I have had a look at some documentation that only provides SCCP protocol phones and the 8961 ip phone isnt in the list? (See below)
http://docwiki.cisco.com/wiki/Cisco_Unified_Presence,_Release_7.x_--_Cisco_IP_Phones_Compatibility
Everyone's tags (7)
1 ACCEPTED SOLUTION
Blue
8961 is not supported with CUPC 7.0
Also it is supported in CUPS 8.X for IPPM not in SCCP or not in SIP.
But it is supported for  MOC Remote Call Contro and  Notify Presence Support SIP and SCCP
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_0/english/compatibility/cupcompatibility8x.html
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Ronak patel
Rate helpful posts.
Community Member
Hi Ronak,
We dont use CUPC, we use Microsoft Lync for MOC Remote Call control with CUPS version 7.0.6.
Does this make a difference? As you have not mentioned that its not supported for this functionality with the 8961 ip phone?
Dwayne
Blue
Hi Dwayne,
Sorry I did noy got your new query. But 8961 with CUPS 7.0 will not work for MOC RCC also.
Ronak patel
Rate all helpful posts.
372
