Cisco Dial Peer Voice VOIP
Dear Sir,
Due to mis-communications of two companies, My Cisco IP telephone Dial extension is conflicting with other newly installed Telephone extension, because its started on same 4.. number.
Example;
Riyadh Branch (4 Digits) 4119
dial-peer voice 551 voip
tone ringback alert-no-PI
destination-pattern 4...$
session protocol sipv2
session target ipv4:200.200.200.13:5068
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
fax protocol none
no vad
*Newly Added Configuration*
Jeddah Branch - (3 Digits) 411
dial-peer voice 302 voip
corlist incoming EMPInt
video codec h263+
session target ipv4:172.16.22.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
What will be the possible soultion, they dont want to change the extension of both Branches/Offices.
All Calls from 4 digits will automatically forward & route to 3 digits extension.
Thanks in advance.
Michael
IT
1 ACCEPTED SOLUTION
Re: Cisco Dial Peer Voice VOIP
Hi Michael,
Here is one solution from my side...
Apply access code to each site which are overlapping .
Suppose for Riyadh Branch access code is 7 and for Jeddah Branch code is 6. Change dial-peer according to access code and apply translation to convert those number to normal 4 and 3 digit numbers after it matches dial-peer.
voice translation-rule 1
rule 1 /^6\(4..$\)/ /\1/
voice translation-rule 2
rule 1 /^7\(4...$\)/ /\1/
voice translation-profile Jeddah
translate called 1
voice translation-profile Riyadh
translate called 2
translation-profile outgoing Riyadh
destination-pattern 74...$
translation-profile outgoing Jeddah
destination-pattern 64..$
Rate all the helpful post.
Manish
Hi Michael,
translate called 1
translate called 2
Manish
Thank you Sir Manish for the
Thank you Sir Manish for the greatful help....
259
