Cisco Directory plugin search within multiple OU
can I configure Call Manager 4.3 integrated with the Active Directory to search the users with different OUs
Re: Cisco Directory plugin search within multiple OU
I believe that you are limited to one search base in that release.
You would have to make your search base high enough so that it will search all subordinates from there.
I have also heard of customer using a LDAP proxy to search multiple select OUs while CCM 4.x points at the LDAP proxy but I do not have direct experience with it.
CUCM 5.x and above address this issue nicely so that could be a compelling reason to upgrade.
just to add something as mentioned point to the common parent OU that covers all you need to achieve that
linux appliances only allow 5 user search bases
java
if this helps, please rate
java
www.cisco.com/go/pdi
How can I configure the search base among multiple OUs in the CM 5.X
Appreciate your cooperation.
add up to 5 different OUs on config, simple as that.
java
java
355
