CISCO DX 650-UNABLE TO GET PLAY STORE--- !!!
Hi Team,
We have multiple Cisco DX650 at our client location.
I have Checked the Parameter in CUCM device page that says allow application from android market.
Even allow application from unknown source is enabled
Tried resetting,rebooting etc no go
Play store icon is visible on few phones but not on all. Is it any kind of a bug? which is causing it? or shall we need to upgrade.
We are on CUCM 9.1.2
Please help this is really an urgent matter as alL this phones are used by VIP users.
Rgds,
Ajith
1 ACCEPTED SOLUTION
Hi Ajith,An out of the box
Hi Ajith,
An out of the box phone will have PlayStore available to user. But, once a config file is downloaded, then PlayStore is immediately disabled by BundledAppInstaller, then config file is read to determine whether admin wants PlayStore to be enabled or not, and thus determine the availability of PlayStore to user.
I did not find any specific bug for this behavior, you can try upgrading to latest load on a DX650 facing the issue and check if the issue goes away.
Manish
Hi Ajith,
Manish
It is working on few phones
It is working on few phones but not on all..
Is there any other troubleshooting which could help?
You can compare a working
You can compare a working phone with a non working one: device pool , firmware , TFTP server / callmanager group information etc can be compared to begin with.
Manish
Hi, Issue is fixed
Issue is fixed automatically dunno what was the problem.. thx for ur support
Scroll down to the bottom of
Scroll down to the bottom of Phone Configuration screen in CUCM and check the box next to
Can you access the play store
Can you access the play store URL using the browser on the DX-650? https://play.google.com/store
I have tried opening the
I have tried opening the playstore directly from browser by logging in to google account
But it wont allow me to download the app..
Rgds,
Ajith
At least that means its not
At least that means its not an issue with the DX650 connectivity to the internet.
Can you download the config files for working/nonworking and compare?  Might be a replication issue if you set it on the phone and the setting is not taking.  Do you have the TFTP server option on the DX650 pointed to the publisher?
1154
