Cisco E1 integration with Nortel
I have integration between Cisco router and Nortel PBX using E1 PRI.The gateway is H.323 and i'm trying to make the caller ID and calling name appear.I have done the configuration as follow:
voice service voip
qsig decode
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 display-ie ccm-compatible
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn supp-service calling name
isdn incoming-voice voice
isdn send-alerting
isdn outgoing display-ie
no cdp enable
Caller ID successfully appear but Calling name is not working. I was thinking is there a feature in CUCM that we can combine between caller ID and Username like translation rules but for names not playing with the numbers?.
Please appreciate your support
Amr Sherif
Hall of Fame Super Gold
Re: Cisco E1 integration with Nortel
Some PBX do not support calling name, or need to have additional features enabled for a charge.
Check with the PBX vendor first, before assuming something is wrong with Cisco.
Hi Paolo,
The issue is not from Cisco side.I did check with PBX engineer and he says that it's not supported from his side.Now the work around is to migrate the PBX to a new hardware with a supported package which is not availabe at that time.Another way is to find a workaround from cisco to make the caller id to be translated to a name as in the translation rule in cucm.
but i cannot find something like that in callmanager. how we can manipulate the callmanager to bind a caller id with a name as in calling transformation rules or translation rules?
Amr Sherif
You can use my TCL/IVR script number2name. It can be aquired at www.ciscoscripts.com
360
