Cisco Emergency Responder
I have a switch in my Cisco CER that the CER can not see. This is the message that I get from the CER :
2010-06-06 00:16:44,464 | INFO  | CER_AGGREGATOR | This device is not supported 10.172.59.18
The switch is a cisco WS-C2960-24PC-L - ISO is :c2960-lanbase-mz.122-44.SE6/c2960-lanbase-mz.122-44.
SE6.bin
The snmp is correct. It is set up just like all the rest. Can you make any sense from that message.
Dave
1 ACCEPTED SOLUTION
Re: Cisco Emergency Responder
You might want to check compatibility for your version of CER i know the 3560v2 switch is only supported on CER 7.1.1B and later you probably need to upgrade CER
I am using a Cisco 2960 switch. Why can't I see that switch?
298
