Cisco Fax server to CUCM 6.X
I have a cisco fax server setup and CUCM 6.01. I am trying to setup the Fax server and CUCM 6.01 for SIP. I'll be using MGCP from the GW to CUCM. Does anyone know of any documentation available for this configuration.
1 REPLY
Silver
Re: Cisco Fax server to CUCM 6.X
When you disable T.38 fax relay, you should also disable fxr-package (which is enabled by default) and reset the MGCP service.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp134404
149
