Cisco FXO outgoing call disconnect after 3 minutes
Dear All
I have CUCM v8.5 and H323 VG , i have a problem on outgoing call for external calls . After i dial external call and connected to it , the call resume to 3 minutes then the call disconnected from my side "VOIP site". The config as below:-
voice-port 0/2/2
 trunk-group FXO2
 supervisory disconnect dualtone mid-call
 battery-reversal answer
 echo-cancel coverage 64
 cptone SA
 timeouts call-disconnect 3
 timeouts wait-release 3
 timing hookflash-out 50
 timing sup-disconnect 300
 connection plar opx immediate 3333
 caller-id enable
voice-port 0/2/3
 trunk-group FXO3
 cptone SA
 connection plar opx 3101
 caller-id enable
voice-port 0/3/0
 trunk-group FXO1
 cptone SA
 connection plar opx immediate 3000
voice-port 0/3/1
 trunk-group FXO4
 cptone SA
 connection plar opx 3102
 caller-id enable
voice-port 0/3/2
 trunk-group FXO5
 cptone SA
 connection plar opx 3103
 caller-id enable
voice-port 0/3/3
 trunk-group FXO6
 ring number 6
 cptone SA
 connection plar opx immediate 3555
Debug:-
Jul 13 16:24:00.315: //28386/8029A0A9CF00/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x354, Source Interface=0x12D79EF8, Source Call Id=28386,
   Destination Call Id=28387, Disposition=0x0, Tag=0x0
Jul 13 16:24:00.315: //28387/8029A0A9CF00/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x354, Source Interface=0x1ECB624, Source Call Id=28387,
   Destination Call Id=28386, Disposition=0x0, Tag=0x0
Jul 13 16:24:00.315: //28386/8029A0A9CF00/CCAPI/cc_generic_bridge_done:
Jul 13 16:24:00.315: //28387/8029A0A9CF00/CCAPI/ccCallDisconnect:
   Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Jul 13 16:24:00.315: //28387/8029A0A9CF00/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 13 16:24:00.335: //28387/8029A0A9CF00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1ECB624, Tag=0x0, Call Id=28387,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is FXO1 success/fail is 1
   Call Disconnect Event Sent
Jul 13 16:24:00.335: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 13 16:24:00.335: :cc_free_feature_vsa freeing 2533DB8
Jul 13 16:24:00.335:  vsacount in free is 1
Jul 13 16:24:00.335: //28386/8029A0A9CF00/CCAPI/ccCallDisconnect:
   Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
TCMGWAN-DC#
Jul 13 16:24:00.335: //28386/8029A0A9CF00/CCAPI/cc_api_get_transfer_info:
Jul 13 16:24:00.339: //28386/8029A0A9CF00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x12D79EF8, Tag=0x0, Call Id=28386,
Jul 13 16:24:00.339: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 13 16:24:00.339: :cc_free_feature_vsa freeing 25343D8
2 ACCEPTED SOLUTIONS
Green
Hi,In you trace I can see
In you trace I can see that you are being disconnected using "CAUSE 19 - No Answer"
In your config you have set up "battery-reversal answer"
And you have set call disc timeout for 3 mins.
I suspect that you do not receive a battery reversal fron the SP when the call is answered.
If the battery reversal is not being received the port is set to drop the call after 3 mins.
I suggest if possible to change the config on ONE voice-port to
voice-port x/x
no battery-revrsal answer
Then restest this port.
If this works then apply the config to all ports
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Hi+5 for Alex . The problem
+5 for Alex . The problem is related to battery-reversal answer , i got same problem before and i got that the customer configured battery-reversal answer  . Kindly find the below:-
voice-port 0/2/2
no battery-reversal answer
sh
no sh
voice-port 0/2/3
sh
no sh
voice-port 0/3/0
sh
no sh
voice-port 0/3/1
sh
no sh
voice-port 0/3/2
sh
no sh
voice-port 0/3/3
sh
no sh
please rate all useful information
Green
voice-port x/x
Hope this helps
Alex
voice-port 0/2/2
sh
no sh
voice-port 0/2/3
sh
no sh
voice-port 0/3/0
sh
no sh
voice-port 0/3/1
sh
no sh
voice-port 0/3/2
sh
no sh
voice-port 0/3/3
sh
no sh
290
