Cisco gateway 2801 H323 to Nortel Signaling Server one way audio
Hi:
I just trying to connect throught a WAN connection one cisco router 2801 configured as H323 gateway and register as a H323 end-point in a nortel signaling server as not ras.   If a realize a call from the site where the 2801 is installed the call progress perfect, if the main site place a call i have one way audio, i check the routes and i can perfect reach any segment of the IP network in both case, here this is my configuration, i post a debug making the call in both ways.  The remote DN are 4..., the main site have 2....
Cisco 2801 (revision 7.0) with 117760K/13312K bytes of memory.
Processor board ID FTX13088JBF
1 DSL controller
2 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
REMOTE_BRANCH#show run
REMOTE_BRANCH#show running-config
Building configuration...
Current configuration : 2736 bytes
version 12.4
hostname REMOTE_BRANCH
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
voice rtp send-recv
voice service voip
allow-connections h323 to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
h323
voice class codec 1
codec preference 1 g729r8
archive
log config
  hidekeys
controller DSL 0/3/0
mode atm
line-term cpe
line-mode 2-wire line-zero
line-rate auto
class-map match-all VOICE
match access-group 106
policy-map VOIP
class VOICE
  set dscp ef
  priority 128
class class-default
  fair-queue
interface FastEthernet0/0
ip address 130.5.0.1 255.255.0.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 130.5.0.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/3/0
no ip address
no atm ilmi-keepalive
interface ATM0/3/0.1 point-to-point
ip address 130.4.0.2 255.255.255.252
pvc 0/100
  protocol ip 130.4.0.1 broadcast
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0/3/0.1
ip http server
no ip http secure-server
access-list 106 permit udp any any range 16384 32767
access-list 106 permit tcp any any eq 1720
access-list 106 permit tcp any eq 1720 any
access-list 106 permit ip any any dscp ef
access-list 106 permit udp any any eq 46
access-list 106 permit udp any any eq 47
access-list 106 permit tcp any any eq 46
access-list 106 permit tcp any any eq 47
access-list 106 permit tcp any eq 46 any
access-list 106 permit tcp any eq 47 any
control-plane
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 2000 voip
destination-pattern 2...
session target ipv4:130.20.0.2
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 8000 voip
destination-pattern 8..
session target ipv4:130.15.0.1
dial-peer voice 400 pots
destination-pattern 4...
direct-inward-dial
port 0/0/0
forward-digits 0
dial-peer voice 401 pots
voice cut-through alert
port 0/0/1
forward-digits 0
dial-peer voice 444 voip
voice-class codec 1
incoming called-number 4000
line con 0
  logging synchronous
login
line aux 0
line vty 0 4
  logging synchronous
login
scheduler allocate 20000 1000
end
show gateway
H.323 ITU-T Version: 4.0   H323 Stack Version: 0.1
H.323 service is up
This gateway  is not registered to any gatekeeper
Alias list (CLI configured) is empty
Alias list (last RCF) is empty
Remote to MAIN
debug h245 asn1
*Apr 20 18:32:11.904: H245 FS OLC OUTGOING PDU ::=
value OpenLogicalChannel ::=
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g729 : 2
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '82050001'H
            tsapIdentifier 17029
          silenceSuppression FALSE
*Apr 20 18:32:11.908: H245 FS OLC OUTGOING ENCODE BUFFER::= 0000000D4001800B0500010082050001428500
*Apr 20 18:32:11.908: H245 FS OLC OUTGOING PDU ::=
        dataType nullData : NULL
        multiplexParameters none : NULL
      reverseLogicalChannelParameters
          sessionID 1
          mediaChannel unicastAddress : iPAddress :
            network '82050001'H
            tsapIdentifier 17028
            network '82050001'H
*Apr 20 18:32:11.912: H245 FS OLC OUTGOING ENCODE BUFFER::= 400000060401004D40018012150001008205000142840082050001428500
*Apr 20 18:32:20.380: H245 FS OLC INCOMING ENCODE BUFFER::= 400001060401004D4001801215000100820D0069145000820D0069145100
*Apr 20 18:32:20.380: H245 FS OLC INCOMING PDU ::=
      forwardLogicalChannelNumber 2
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:32:20.384: H245 FS OLC INCOMING ENCODE BUFFER::= 0000000D4001801215000100820D0069145000820D0069145100
*Apr 20 18:32:20.384: H245 FS OLC INCOMING PDU ::=
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:32:20.388: H245 MSC INCOMING ENCODE BUFFER::= 023001060008817500070480000030C01380000130401380000232C0018000033408010180000485014000800001030000000100020003000004
*Apr 20 18:32:20.388: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      capabilityTable
          capabilityTableEntryNumber 1
          capability receiveAndTransmitAudioCapability : g711Ulaw64k : 20
          capabilityTableEntryNumber 2
          capability receiveAndTransmitAudioCapability : g711Alaw64k : 20
          capabilityTableEntryNumber 3
          capability receiveAndTransmitAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 4
          capability receiveAndTransmitAudioCapability : g729AnnexAwAnnexB : 2
          capabilityTableEntryNumber 5
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
      capabilityDescriptors
          capabilityDescriptorNumber 0
          simultaneousCapabilities
              1,
              2,
              3,
*Apr 20 18:32:20.392: H245 MSC INCOMING ENCODE BUFFER::= 01003C806CB5D6
*Apr 20 18:32:20.396: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 7124438
*Apr 20 18:32:20.396: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision slave : NULL
*Apr 20 18:32:20.396: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
      sequenceNumber 1
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 30
          capability receiveRTPAudioTelephonyEventCapability :
            dynamicRTPPayloadType 101
            audioTelephoneEvent "0-16"
          capabilityTableEntryNumber 21
          capability receiveAndTransmitDataApplicationCapability :
            application nonStandard :
              nonStandardIdentifier h221NonStandard :
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              data '52747044746D6652656C6179'H
            maxBitRate 0
          capabilityTableEntryNumber 27
          capability receiveUserInputCapability : hookflash : NULL
          capabilityTableEntryNumber 26
          capability receiveUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 23
          capability receiveUserInputCapability : basicString : NULL
          capability receiveAudioCapability : g729AnnexA : 2
          capability receiveAudioCapability : g729 : 2
          capabilityDescriptorNumber 1
              4,
              26,
              23,
              21
              27
*Apr 20 18:32:20.412: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC0010001000680001D8A061404302D31368000144810B50000120C52747044746D6652656C6179000080001A83015080001983014080001683011080000422C00180000322800100800102010003000403001D00190016001400001A
*Apr 20 18:32:20.416: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
*Apr 20 18:32:20.416: H245 MSC OUTGOING ENCODE BUFFER::= 218001
*Apr 20 18:32:20.448: H245 MSC INCOMING ENCODE BUFFER::= 2080
*Apr 20 18:32:20.448: H245 MSC INCOMING PDU ::=
      decision master : NULL
*Apr 20 18:32:20.464: H245 MSC INCOMING ENCODE BUFFER::= 01003C806CB5D6
*Apr 20 18:32:20.464: H245 MSC INCOMING PDU ::=
      terminalType 60
*Apr 20 18:32:20.464: H245 MSC OUTGOING PDU ::=
*Apr 20 18:32:20.464: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
*Apr 20 18:32:20.464: H245 MSC INCOMING ENCODE BUFFER::= 218001
      sequenceNumber 1
*Apr 20 18:32:20.504: H245 MSC INCOMING ENCODE BUFFER::= 2080
*Apr 20 18:32:20.504: H245 MSC INCOMING PDU ::=
csim err csimDisconnected recvd DISC cid(1130)
*Apr 20 18:32:30.336: H245 MSC INCOMING ENCODE BUFFER::= 02000206000881750007
*Apr 20 18:32:30.336: H245 MSC INCOMING PDU ::=
      sequenceNumber 2
*Apr 20 18:32:30.336: h245_decode_cap: Term has no caps at all
*Apr 20 18:32:30.340: H245 MSC OUTGOING PDU ::=
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
REMOTE_BRANCH#closeLogicalChannel :
      source user : NULL
*Apr 20 18:32:30.340: H245 MSC OUTGOING ENCODE BUFFER::= 0400000000
      sequenceNumber 2
*Apr 20 18:32:30.340: H245 MSC OUTGOING ENCODE BUFFER::= 218002
*Apr 20 18:32:30.344: H245 MSC INCOMING ENCODE BUFFER::= 0480000100800100
*Apr 20 18:32:30.344: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
      source user : NULL
      reason unknown : NULL
*Apr 20 18:32:30.344: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : closeLogicalChannelAck :
*Apr 20 18:32:30.344: H245 MSC OUTGOING ENCODE BUFFER::= 23800001
*Apr 20 18:32:30
REMOTE_BRANCH#.344:
*Apr 20 18:32:30.352: H245 MSC INCOMING ENCODE BUFFER::= 0480000100800100
*Apr 20 18:32:30.352: H245 MSC INCOMING PDU ::=
      source user : NULL
*Apr 20 18:32:30.352: H245 MSC OUTGOING PDU ::=
*Apr 20 18:32:30.352: H245 MSC OUTGOING ENCODE BUFFER::= 23800001
*Apr 20 18:32:30.356: H245 MSC INCOMING ENCODE BUFFER::= 0580000002800100
*Apr 20 18:32:30.356: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : requestChannelClose :
*Apr 20 18:32:30.356: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : requestChannelCloseAck :
*Apr 20 18:32:30.360: H245 MSC OUTGOING ENCODE BUFFER::= 24000000
*Apr 20 18:32:30.360: H245 MSC INCOMING ENCODE BUFFER::= 4A40
*Apr 20 18:32:30.364: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= command : endSessionCommand : disconnect : NULL
*Apr 20 18:32:30.364: H245 MSC OUTGOING PDU ::=
*Apr 20 18:32:30.364: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
MAIN TO REMOTE
debug h245 asn1
REMOTE_BRANCH#
*Apr 20 18:30:33.212: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004C6013801114000100820D0069145000820D00691451
*Apr 20 18:30:33.212: H245 FS OLC INCOMING PDU ::=
      forwardLogicalChannelNumber 323
        dataType audioData : g711Ulaw64k : 20
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
REMOTE_BRANCH#    }
*Apr 20 18:30:33.216: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004C6009801114000100820D0069145000820D00691451
*Apr 20 18:30:33.216: H245 FS OLC INCOMING PDU ::=
        dataType audioData : g711Ulaw64k : 10
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.220: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004C2013801114000100820D0069145000820D00691451
*Apr 20 18:30:33.220: H245 FS OLC INCOMING PDU ::=
        dataType audioData : g711Alaw64k : 20
          sessionID 1
REMOTE_BRANCH#ss :
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.220: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004C2009801114000100820D0069145000820D00691451
*Apr 20 18:30:33.224:
*Apr 20 18:30:33.224: H245 FS OLC INCOMING PDU ::=
        dataType audioData : g711Alaw64k : 10
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.224: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004D6001801114000100820D0069145000820D00691451
        dataType audioData : g729AnnexA : 2
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.228: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004D6000801114000100820D0069145000820D00691451
*Apr 20 18:30:33.228: H245 FS OLC INCOMING PDU ::=
        dataType audioData : g729AnnexA : 1
REMOTE_BRANCH#50LogicalChannelParameters :
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.232: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004E040101801114000100820D0069145000820D00691451
*Apr 20 18:30:33.
REMOTE_BRANCH#232:
*Apr 20 18:30:33.232: H245 FS OLC INCOMING PDU ::=
        dataType audioData : g729AnnexAwAnnexB : 2
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.236: H245 FS OLC INCOMING ENCODE BUFFER::= 400142060401004E040100801114000100820D0069145000820D00691451
*Apr 20 18:30:33.236: H245 FS OLC INCOMING PDU ::=
REMOTE_BRANCH#323
        dataType audioData : g729AnnexAwAnnexB : 1
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
*Apr 20 18:30:33.240: H245 FS OLC INCOMING ENCODE BUFFER::= 0000000C6013801114000100820D0069145000820D00691451
*Apr 20 18:30:33.240: H245 FS OLC INCOMING PDU ::=
          sessionID 1
            network '820D0069'H
            tsapIdentifier 5200
            network '820D0069'H
            tsapIdentifier 5201
719
