07-08-2013 07:06 AM - edited 03-16-2019 06:16 PM
Hi everyone--we're in the process of transitioning from a Nortel CS1000/Meridian based environment into Cisco CallManager. Right now, we've got two sites left in the US that are still Nortel. Recently, we've had a series of issues with people reporting static and poor call quality when calling from a Cisco phone to one of the Nortel sites. I'm seeing slips on the T1 controller in the Cisco gateway, but i've seen those since I came into the environment (it was started about 8 months before I came to the organization), and this is the first time we've had reports like this.
Does anyone have any experience with integrating into a Nortel environment via a PRI (virtual PRI in the Nortel) and having issues like this? Not sure what to look for since the slips have been present from day one...
07-18-2013 05:45 AM
A quick update to this--we're still troubleshooting the issue. We've replaced the physical cables between the Nortel backplane and the Cisco gateway, replaced the PRI card in the CS1000 unit, and replaced the entire physical Cisco gateway with a spare we had, but we're still having issues.
Does anyone have any other ideas?
07-18-2013 06:00 AM
Post "show controllers T1" and "show network-clock".
07-18-2013 06:03 AM
Hey Paolo--appreciate the help. Info is below:
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (76 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 11 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
WHVGW01#sh network-clock
Network Clock Configuration
Priority Clock Source Clock State Clock Type
1 T1 0/0/0 GOOD T1
10 Backplane GOOD PLL
Current Primary Clock Source
1 T1 0/0/0 GOOD T1
07-18-2013 06:44 AM
Circuit is perfect, issue is caused by something else.
You should check who hears static, Cisco or Nortel user, or both.
07-18-2013 06:47 AM
Excellent point--only people hearing the issue are the Cisco users...the Nortel users don't hear anything. That part is consistent...
07-18-2013 06:56 AM
You can insert a digital testset in passtrough mode between Cisco and Nortel, and listen to some (test) calls. If noise is heard coming from Nortel side, that proves it's their problem that they have to fix.
07-18-2013 06:59 AM
That's a great idea...I'll have to work with my Nortel guy monday when he's back in the office. Thanks for the idea. I'll let you know how it works out...
07-26-2013 05:57 PM
Scott,
Did you ever figure out what the problem was?
We've been running Nortel and Cisco for a couple of years now and Centurylink just upgraded the Nortel from 5.0 to 7.0. Now we are experiencing what you describe at two of our hospitals.
Dave
07-26-2013 08:35 PM
Hey Dave. We're still verifying, but what I suspect was a bad Ethernet cable between the gateway and our core. Not sure why (machine-made cable that's been in place for a year), but the reports have been indicating improvement. If it changes, I'll make it a point to post another update.
