Cisco HRC issue
I am using ISM-SRE-300-K9 on CME 2911, i enabled HRC on CUE and installed UCEHistoricalReportsInstall on windows Machine, i got Call-In number 331 for IVR number, when i generator report for 331 it is working
When i select Extension number, it not work
The issue message:
There were no report date to view in the date range selected. Please select a different date range by changing the start date/time or the end date/time and try again
How can i fix the problem
  • IP Telephony
1 ACCEPTED SOLUTION
Are you trying to run a
Are you trying to run a report on a phone extension to see it's calls?  If so, this isn't going to work.  This will only give you information for calls into the CUE.
My IVR working as: The caller
My IVR working as: The caller going to E1 Trunk, then route to IVR number on CUE, the IVR on CUE play prompt for selection language, the caller selected language, the IVR play Menu Prompt, the caller press 1 to meet Reservation team, then the IVR will transfer the call to hunt group 441, now the call will be established from caller to Reservation Extension(member of hunt group). I would like HRC recorded the this call ?
Anyone help me ?
Anyone help me ?
Dear adcompto, Please kindly
Dear adcompto,
Please kindly help me as below post
Here is an excellent post on
Here is an excellent post on call accounting and reporting options in CME.  It was written with the UC500 in mind, but everything also applies to CME.
https://supportforums.cisco.com/document/36401/call-accounting-reporting-software-cme-and-uc500
That is a good place to start.
56
