Cisco IAD 2431: SIP user agent
pls, any one can tell me how many SIP user agent can i put on IAD 2431 T1/E1?
exp Config for 1 sip user agent:
dial-peer voice 11111 pots
destination-pattern 11111
direct-inward-dial
port 1/0:15
forward-digits all
authentication username 11111 password xx
Cordially
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cisco IAD 2431: SIP user agent
Either use "service compress-config", or save/load config from server.
What is your purpose ? If you want to authenticate callers that do sip to pots calls, apparently you can use a different username for each port.
If you want to register your router to some external sip server, you can have only one set of credentials.
I have 150 sip user assotiated to dial_peer. each SIP user are registred to my SIP provider.
I want to know who many SIPuser/peer can'i use on IAD 2431.
see attached file
I believe there is no hard limit.
i think so, but the limit of the nvram can cause problem if the configuration file is big than nvram volume.
correct me pls.
1088
