Cisco Integration with Nortel SRG 50
One of my customer is looking to deploy Call Manager solution. They are using Nortel CS 1000M, SRG 50 Gateway and Nortel IP phones. I am looking for a solution to  use existing Nortel phones, switches and SRG 50 gateway with Cisco Call Manager, Is it doable?
Thanks.
Hall of Fame Super Gold
Re: Cisco Integration with Nortel SRG 50
No.
Only use Cisco phones and switches with Cisco Call Manager.
Can I use those Nortel equipment at branch location using H.323 gateway protocol.
Thanks.
You could setup H.323 between PBX and CM.
Recommend you engange a certified dealer or reputable consultant, as it is not a task for the inexperienced.
Remember to rate useful posts clicking on the stars below.
550
