11-01-2011 09:45 AM - edited 03-16-2019 07:49 AM
Hello all,
Does anyone know if this is available for UCM 8 now? I can see versions for 5, 6 and 7 but not 8.
Any help would be good.
Solved! Go to Solution.
11-02-2011 07:20 AM
Did you remember to go to Call Routing > Dial Plan Installer, and click install, after installing the file from the OS Administration, Software Upgrades, Install/Upgrade? I always forget this step myself.
11-02-2011 04:12 AM
You can use the CUCM 7.x compatible dial plan installers for CUCM 8.x:
11-02-2011 06:44 AM
Thanks for this.
I have installed the latest as you can see here...
Installed Software Options |
Option Name | Status |
ciscocm.dst-updater.2011h-1.el5.8.0.3.cop | Active |
cm-locale-ca_ES-8.0.3.2000-1.cop | Active |
cm-locale-en_GB-8.0.3.2000-1.cop | Active |
In the numbering plan when tryig to add a pattern, I only get NANP still, so no joy I am afraid. Have tried this on 8.0.3 and 8.5.
11-02-2011 07:20 AM
11-02-2011 07:56 AM
Joe!
A true star! Yes this worked fine!
Many thanks for your help!!
