Cisco International Dial Plan for UCM 8
Hello all,
Does anyone know if this is available for UCM 8 now? I can see versions for 5, 6 and 7 but not 8.
  1. Cisco International Dial Plan
Any help would be good.
1 ACCEPTED SOLUTION
Did you remember to go to Call Routing > Dial Plan Installer, and click install, after installing the file from the OS Administration, Software Upgrades, Install/Upgrade?  I always forget this step myself.
You can use the CUCM 7.x compatible dial plan installers for CUCM 8.x:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtr44481
Thanks for this.
I have installed the latest as you can see here...
Installed Software  Options
Option Name Status
ciscocm.dst-updater.2011h-1.el5.8.0.3.copActive
cm-locale-ca_ES-8.0.3.2000-1.copActive
cm-locale-en_GB-8.0.3.2000-1.copActive
In the numbering plan when tryig to add a pattern, I only get NANP still, so no joy I am afraid. Have tried this on 8.0.3 and 8.5.
Joe!
A true star! Yes this worked fine!
Many thanks for your help!!
571
