Cisco IOS Translation Rule
  Hello all ,
i have range of DID extensions and i want to translate them when calling outside to appear as the pilot number and when somone is calling from outside he shouldnt be able to call any of them and instead of the call rings directly on the user ext it should be forwarded to the PRI line pilot number
Range is 07018450 - 07018469
pilot number is :07018444
please help with the same
rgards.
Is the gateway H.323 or MGCP ?
Amer
its Cisco ISR 3845 H.323 and ccm 6.1
Are you using 4 digit extension
Voice translation-rule 1
Rule 1 /070184[56]./ 07018444/
Voice-translation profile p1
translate called 1
On the pots dial peer of isdn use the above profile inbound
Dial peer voice x pots
Translation profile incoming p1
if helpful rate
428
