Cisco IP 7941 Phone do not reply busy when a call already is in progress on the phone.
In our "Cisco Unified CM Administration System version: 7.0.1.11000-2" installation, I have a CISCO IP Phone 7940 series with the number 1595.
In the "Multiple Call/Call Waiting Settings on Device SEP0014691B5534", I have configured the phone with:
Maximum Number of Calls: 2
Busy Trigger: 2
What I would like to archive is that I would like to see in the display if another user is calling me (even if I already have a call in progress), but if I already have a call in progress, I would like to have the second call to sound as busy when they call me.
Is this possible to configure, or have I misunderstood something what can and cannot be done?
Kind regards,
Carl-Marius
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: Cisco IP 7941 Phone do not reply busy when a call already is
Hi Carl-Marius,
Many people have enquired about this over the years
Sadly, (but understandably) this is an either/or situation. If you
want to be able to handle multiple incoming calls, then you need to set
the Busy trigger @ 2 (like you have done). If you want the second caller
to know that the person is already on an active call you usually set the Busy Trigger
@ 1 and indicate via your "on the phone" greeting that is available in most
current Voicemail systems.
You can't have it both ways here
Cheers!
Rob
Ps: if you are going to set the Busy trigger @ 2 you should bump
up the Max Calls to 4 to handle Transfers etc.
Red
You may set busy trigger to one.  Then the 2nd call will get a busy.  But you won't see the 2nd call coming in.  Because the phone will only display the 2nd call when it's in "Ring-In-Progress" state.
Michael
http://htluo.blogspot.com
Hi Carl-Marius,
Cheers!
Rob
Red
Michael
Hi Michael and Rob,
Thank you both for your quick answer! I tried a lot of combinations but could not seem to get the right one...
Now I know it was because it simply can not be done.
Thank you very much - Both! I really appreciate it!
Kind regards,
Carl-Marius
Hall of Fame Super Gold
If you are interested in an TCL/IVR extension that lets the calling party know the person is on the phone, contact me at the address present  in my profile.
1123
