Cisco IP 9971 registration rejected
Hi All,
Have an IP Phone 9971 which registration status is rejected.
CUCM is 8.5.1.10000-26 with SIP 9971.9-1-1SR1 device firmware.
Please tell me if its is a firmware problem.
Thanks in advanced.
1 ACCEPTED SOLUTION
Make sure the phone doesn't show any errors about failing to update it's CTL or ITL.  If that's the case the phone might not be accepting it's configuration and may be still trying to register an old directory number.  You can check in the call manager traces for a register from the phone's IP address to see what line number it's trying to register.  If you match CUCM's configuration to the same line you should see the phone register.  To fix the phone you can erase the ITL or CTL so the phone downloads a new one that will be able to authenticate the configuration file from CUCM.
Re: Cisco IP 9971 registration rejected
Did you configure a dn on the line ?
Sip phones will not register without a dn.
Cheers
Steffen
Hi Steffen,
Yes I did, and a digest user too if it was requiered.
What else do you think would be the problem ?
Hi Joe,
You're right, it was the CTL.
Thanks a lot.
Hello, i am facing
i am facing registration rejected after using extension mobility on 9971.
i am having cucm 9.1.X version and 9971 running 9.3.1.2 version IOS>
before using extension mobility, ip phone is registering and working perfect.
what is issue after using mobility as extension mobility login also working successfully.
Warm Regard's =========== Amit
4526
