Cisco IP Communicator and Windows - left click to dial
Hi all
two qustions
1 is there a way for highlighing a number of the screen be it in a browser or a text document and then getting Communiicator to dial it
2 can you "edit" the number prior to dialling - e.g. the number might be +353 (0) 1234 5678 when you want dialled +353 1234 5678
That's click to dial, and that's not provided by IPC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
unfortunatlty that link is failing for me - can you re-post
You need to be a partner to access the link, and that's not specifically for you, that goes on every single of my replies on CSC
java
java
116
