Cisco IP Communicator Blank Screen
Hi Friends,
We are running Cisco IP Communicator v2.X but the issue is we are getting Blank screen.
The operating system is windows XP...
Could you please let me konw if any faced the issue before.. Your answer is much appriciated...
Hall of Fame Super Silver
Re: Cisco IP Communicator Blank Screen
Are you using cucm or cme? What version? Is it defined with proper tftp ip address?
Blue
Try to upgrade your JAVA in the operating system.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
hi
what is the connectivity between pc and server. Is there any vlan, check the tftp service in server is active,
also check auto registration is enable or not. check all the java plug-ins in pc was installed or not.
Praveen Kumar GVK
We are running CUCM 8.5 version and the IP communicator version is 7.0.4.0 with win 7 OS.
Kulasekararaja -
Any resolution to this issue?
Amir
Reinstall the cipc was solved our same problem.
2569
