Cisco IP Communicator doesn't register in VPN (Cisco VPN client)
We currently have a Cisco 2901 running Cisco Unified Communications Manager Express.
We're running Cisco IP Communicator 2.1.2.0.
We're running Cisco VPN Client 5.0.07.0410
We have a Cisco ASA Firewall
When I launch CIPC, it becomes stuck at the "Registering" process only when I am VPNed into the network.....using both wireless or a cable.
What I've done:
1. I can ping the Call Manager/TFTP successfully.
2. I have added the MAC info for the wireless card and the Cisco VPN adapter to the call manager.
3. I have the TFTP IP set in CIPC under  Preferences->Network->TFTP Servers.
While it's "Registering", if I disconnect from VPN and plug into my local network, it registers in a second.
What am I missing here?
Phil...
Phil,
Is there a policy in your ASA that may be blocking the traffic?
Best,
David
Hi David,
No, there are no rules blocking traffic.
Hi Everyone,
Hi Everyone,
Under "audio" , I went to the network option and I got a default IP address in the  "use this address" option which corrected my issue.
Hi Phil,
In your CIPC client make sure that you select "Cisco VPN Client Adapter" to be used by CIPC and not your wireless adapter.
Re: Cisco IP Communicator doesn't register in VPN (Cisco VPN cli
open the command prompt as an administrator
e.g  go to all programs > accessories > command prompt > rightclick > open as administratior
on the c:\ prompt write the follwoing command:
C:\>netsh int tcp set global autotuninglevel=disabled
Tried that command, and still the same results.
Hi Mohammed,
I've already added both the wireless and Cisco VPN adapter mac addresses to my call manager and tested in CIPC for both. Doesn't pass the "registering" phase.
Phil,
I assume you are able to access other network resources over the VPN? Do you see the traffic from CIPC on the network with wireshark, or on the CME box - debug tftp events ? Can you ping the VPN client from the CME router?
Best,
David
Hi David,
Yes. I can access all other resources over the VPN network. And yes, I can ping the VPN client from the CME router and vice versa.
Using Wireshark, I see several read requests followed by, no such file.
102 68.474312  TFTP 73 Read Request, File: CTLSEPA4BADBDE33E5.tlv, Transfer type: octet
103 68.500206  TFTP 59 Error Code, Code: File not found, Message: No such file
The files exist, otherwise I'd see the same errors when I'm connected to my network without VPN.
Thoughts?
Phil
Hi David,
I was wondering if you had a chance to see my reply to this.
I'm able to ping from the client to the cucm and vice versa.
Any other ideas?
Phil
Hi Phil,
I am not talking only about cucm side. In cipc client you need to set the source interface under preferences menu. There you shld select vpn client interface. Then you shld configure vpn mac in cucm.
Hi Mohammed,
Thank you for the response.
And yes, I changed the source interface in CIPC as well as in CUCM.
Phil
VIP Purple
Hi Phil,
I do not have that much idea on ASA but for VoIP protocols we need to enable inspection of protocols.
Please find the URL .
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
regds,
aman
All the proper protocols seem to be set up on my ASA.
The only errors that I see in Wireshark when connected through VPN, are:
Hello Phill;
During registration please add the cipc as SEPXXXXXXXXXX like SEP(MAC Address of CIPC).,
Please let me know the status.
Hope to help, please remember to rate the post if it does.
Regards!
Afsal
Hi Afsal,
Thanks for the suggestion, but I already tried that. I mentioned the steps I took in my initial post, and adding the MAC of both my wireless adapter and the Cisco VPN Adapter into the call manager.
Any other ideas?
Although I can ping back and forth between the call manager (tftp server) and the laptop (while connected through VPN), it continues to hang at the registration.
Phil
Phil,
Another option is to turn on auto registration and let the CIPC auto-register with CUCM.  Then you'll see exactly what MAC address it was trying to use.  Alternatively just make one up. Unless you are recording calls you can create your own devicename.
Another thing to check is the binding order of your network adapters in Windows.  Make sure the Cisco VPN client adapter is 'above' the Wiresless and Ethernet adapters in the binding order.
-Steven
Please help us make the communities better. Rate helpful posts!
I had the same problem and
I had the same problem and nothing was blocking it.
Change of version for CIPC resolved the issue.
6062
