Cisco IP Communicator not working in Windows 7
We upgraded our windows OS from XP to Windows 7. Since then Cisco IP Communicator is not working through VPN. With in office it works fine.
The IP Communicator get registered and we are able to hear the dial tone, but when the call connects no Voice.
Pls suggest.
Jagadish
Have you checked the option under IPC preferences to optimize for low bandwidth?
Voice CCIE #37771
Yes, i have tried that also and also audio port range. Strange is call shows connected but no voice from both ends.
This works perfectly fine with XP Machine. Only with Windows 7 machine it doesn't work. Disabled the windows firewall also and check. But no luck.
213
