cisco ip communicator registration problem
Good morning, I've a callmaanger 10.0.1 and all works wel.
 I've registered a cipc and it works wel, but   on the phone display appears Always  the service menu. (see attached file)
Eachone can help me?
Thanks in advance
Giancarlo
2 Accepted Solutions
Chris Deren
This is probably because you are using https services, change them to http and it should be resolved.
Chris
Brian Meade
Level 7
Level 7
That's part of the CUCM 10.0 self-provisioning.
CIPC will always show a blank services window for the self-provisioning since it doesn't support HTTPS.
Under the phone configuration, remove the Idle URL and then save and reset.
You can update the Universal Device Template you're using for auto-registration to not contain the Idle URL if you are not going to be using the self-provisioning feature.
5 Replies 5
Chris Deren
Chris
Hi at all I'm trying  to check alla suggestion.
Just a few minutes....
The self-provisioning service in CUCM 10.x only runs as HTTPS.
Brian Meade
Level 7
Level 7
giancarlo
