cisco ip communicator registration problem
Good morning, I've a callmaanger 10.0.1 and all works wel.
 I've registered a cipc and it works wel, but   on the phone display appears Always  the service menu. (see attached file)
Eachone can help me?
Thanks in advance
Giancarlo
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
This is probably because you
This is probably because you are using https services, change them to http and it should be resolved.
Chris
That's part of the CUCM 10.0
That's part of the CUCM 10.0 self-provisioning.
CIPC will always show a blank services window for the self-provisioning since it doesn't support HTTPS.
Under the phone configuration, remove the Idle URL and then save and reset.
You can update the Universal Device Template you're using for auto-registration to not contain the Idle URL if you are not going to be using the self-provisioning feature.
Chris
Hi at all I'm trying  to
Hi at all I'm trying  to check alla suggestion.
Just a few minutes....
The self-provisioning service
The self-provisioning service in CUCM 10.x only runs as HTTPS.
giancarlo
192
