02-13-2008 12:52 AM - edited 03-15-2019 08:48 AM
The Cisco Call manager is version 4.2 using a private network of IP addresses.
Regular IP phone calls are working well in every direction.
The problem that I'm experiencing, is when two people, connected via Cisco VPN and using the Cisco IP Communicator software are not able to hear each other at all. The phone call is normally established but the calling parties are not receiving any sound on both ends. Cisco IP communicator via VPN to a regular phone or office IP phone is working well.
My question is, where should I start debugging the problem (where is it most likely to find it) - Cisco VPN concentrators, Cisco call manager, the soft phones? Could it be a firewall issue too?
Thank you forward.
Kiril
02-13-2008 08:22 AM
Hey there Kirl,
We have run into the same problem here. We haven't fixed the problem but from our understanding it is an issue with the firewall.
Since the phones get set up through the callmanager, the skinny singaling should work. But it's the rtp that's having an issue from VPN to VPN. I do believe the place you need to look is your Firewall
02-13-2008 08:35 AM
In this kind of situation, for the two-way audio to work you would have to have both VPN clients IP addresses has to be route-able.
