Cisco IP Communictaor on CME
Is there a way to setup the Cisco Ip Communicator on Call Manager Express? Do I need to download some kind of firmware?
I would like to have some setup guide in the case it could be posible.
Thanks in advance
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Everyone's tags (2)
1 ACCEPTED SOLUTION
Just to give a bit more information, no firmware (or loads) file is required for CIPC to work with CME. You provision the phone just as you do any other, but under the ephone you give it type CIPC.
For example:
ephone  4
 mac-address 0011.5555.666B
 paging-dn 45
 type CIPC
 button  1:1 2:5
Best,
David
Yes. Take a look:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1046762
Hope to help, please remember to rate the post if it does.
Kind regards,
- Adrian.
For example:
ephone  4
 paging-dn 45
 type CIPC
 button  1:1 2:5
Best,
David
You definitley can.  I set mine up for auto-registration.  It worked fine.  http://www.youtube.com/watch?v=zr_DvT8sJHM
Blue
HI
What version of CME you are using. For CIPC you need Cisco Unified CME 4.0 or a later version. If you are running above this CME version, CIPC can be added like anyother phone.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
1538
