Cisco IP Conference Station 7937
I want to know how many maximum numbers of conferences I can make using the above phone? I have call manager express (UC560 Phone system). I am trying to add 3 outside numbers to do the conference but it is not allowing me. I can only add two outside numbers for the conference (including me 3). Want to know are there any settings to increase the number of conferences or this is the maximum.
Below are the settings for the phone:
ephone 28
device-security-mode none
mac-address 0004.F2EB.8EA5
type 7937
button 1:115
Hi Muhammad,
1. For Ad-Hoc conferencing, please make sure you have the phone configured as Octo-Line and not Dual-Line, this way you can have up to 8 active participants, otherwise if you want more then use Meet-Me
2. Make sure the UC has conferencing enabled so the 7937 can be fully used
Also please refer the below thread on the same topic,
https://supportforums.cisco.com/thread/2124011
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
Dear Anchoudh,
Thank you very much for the reply. Could you please let me know how to check whether the phone is configured in as Octo-Line and not Dual-Line. Also how to check that UC has conferencing enabled.
Asking this because I am very new to UC560.
Regards.
Hi Muhammad,
Octal line or Dual Line is defined under the ephone-dn for each ephone.
Regarding Conferencing refer the below link,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_1/administration_guide/cca_31_sbcs_admin_guide.pdf
Hope it helps.
Anand
Dear Anchoudh,
This is my configuration for the phone:
ephone-dn  115  dual-line
number 115 secondary 0xxxxxxxx no-reg primary
pickup-group 1
label Board Room Conference Phone
description 115
name Board Room Conference Phone
call-forward noan 0 timeout 15
corlist incoming user-international
corlist outgoing call-local
Shall I simply go into conf t mode and delete this:
no ephone-dn 115 dual-line
and create a new one:
ephone-dn 115 octo-line
pickup-group 1
description 115
Will it work?
Yes, please try that and see if it works.
Anand
Dear Anchoudh,
I tired that. The commands work fine but the phone stopped working. I mean I cannot dial a number using the conference phone.
Oh Sorry I have to add this "button 1:115" in the ephone:
ephone  28
type 7937
Dear Anchoudh,
It is working and I can dial 3 or more extensions at one time. But a small problem I facing. Somehow I cannot join them. Whenever I push the Confrn softkey, it asks me to add a new participant’s phone number. I don’t know what is missing I should have a button to join them.
Could you please let me know if I am missing anything?
Hi Muhammad,
Please see if you have the below requirements met,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_1/release/Notes/cca_3_1_relnotes.pdf
Also could you please clarify what types of numbers (PSTN, VOIP, Mobile) are you trying to join in the above scenario?
Hope it helps.
Anand
Please rate helpful answers !!
1179
