Cisco IP Phone 7841 Screen display show picture Snoopy cartoon.
When I unpack the phone from the box. I plug the phone for register to cisco call manager. but the phone display picture snoopy. after display I can't press anything with it
  • IP Telephony
Have you tried DHCP??
java
if this helps, please rate
www.cisco.com/go/pdi
Hi JaimeYes, I already try
Hi Jaime
Yes, I already try dhcp server.
Thank you.
We also got the same problem.
We also got the same problem...Might I know if it been solved yet?
Just wondering if there are
Just wondering if there are any updates regarding this issue.  The phone is basically a brick, with a picture of Snoopy and Woodstock.
Snoopy was the internal code
Snoopy was the internal code name for this phone.  Most likely it didn't get flashed with the right firmware during manufacturing.  If the phone isn't picking up a DHCP address, it will need to be RMA's as a DOA.
879
